I have already ordered my Freescale samples and they should be on there way soon.
My build will be very simple and I will only be running wasted spark to begin with.
I knew that I had a box that I found years ago and thought that it would be the right size.
I just found it and it's great fit.
OK the the colour is Sh*t but I can fix that with paint.
Some of the pads are a bit close to the pads but I can deal with that.
My next step is to put on the power supply components and check all the voltages are correct.
You don't want to find that your voltages are not right when you have the Micro soldered on.
I have found most of my sensors that I have been collecting over the years but I still can't find my ignition drivers. Might be a trip to pick-a-part coming up.
Aaron
