D'oh I noticed today that I had soldered on both the pull up and pull down on the XOR. This caused 2.5V on the input and caused the out to flip flop at will.I did notice that on one setup the whole wave form got inverted. like the Xor had changed state. That didn't make sense. It might help with debugging.
Spudmn's Puma board build
- Spudmn
Re: Spudmn's Puma board build
And so hw designs develop, three pads = that's not possible :-)
- Spudmn
I changed the ignition driver to 12V. Here is the circuit. I still want to add an LED.
Note that R30 creates a voltage divider network, and although it's 100:1 it's a bit ugly, I think I removed mine, as it's not strictly necessary anyway, and when used should be on the other side of the 1k. Otherwise fine :-) I can't comment on the correctness of the pull up/down on the XOR, but if you're sure that it's happy and dwelling for a short time, pausing for a long time, then I'll double check it and get it added to the docs :-)
Spudmn, make sure you grab the latest from the dev branch before turning the key again! It has a major fix in it which you need! Good luck getting a nice video of engine number 8 for us! And congratulations on the achievement! :-)
OK, definitely all fixed now, just checked, my mistake in config, woops! Woo hoo, number 9 is just around the corner! :-)
- Spudmn
I needed a way of timing my set up before I tried to start the engine. I don't have a timing light yet and I only had a logic analyser.
I wanted to know what timing the distributor had but I couldn't feed 12V into my LA. I had an RS232 to TTL board on my shelf. It's just a ST202 chip and caps. I wired the RX in to the points and RX out to the LA. Worked like a treat, converting the 12V signal from the points to 5V for my LA. The output was inverted but I didn't care.
Running the engine with points and distributor I could then compare the points to FreeEMS. I configured it until they matched. This is only a very rough set up at one RPM and Load and I will need to time it properly.
I might use this method to to capture the advance curve of the distributor.
You forgot to post the vid that you uploaded. I hope there wasn't a reason for that, so I'm going to do it for you, don't kill me.
http://www.youtube.com/watch?v=3GM56iAK59M
Very cool mate! Congrats!
I downloaded one of the files overnight - FOUR HOURS lol :-) Will grab the other one later today and try to do something with it, though my computer/net situation here is not good.
- Spudmn
I managed get a timing light working and checked that my trigger wheel was timed correctly. It was. By luck I didn't need to add any offset in the code.
I set the advance curve to flat 10 Deg and checked the timing with a scope while still running on the distributor. Every thing looked good so I fired it up again on FreeEMS.
It started up fine and ran very smooth. My distributor was runing a lot more advance than 10 so I changed the curve to flat 15. Fired up and ran better.
My next question is how do I work out the advance curve I need?
