- Moderator
Post
by Fred »
Fred wrote:Don't "nah" me... how rude!
nitrousnrg wrote:Ooh, you only have the cpu.
Can you get a 16MHz SMD crystal and the 0805 stuff?
Are you going to apologise? Or just ignore what you did?
nitrousnrg
Post
by nitrousnrg »
Fred wrote:Are you going to apologise? Or just ignore what you did?
Nah :p I thought you were kidding, 'nah' is not rude at all from where I come. Sorry for the inconvenience.
Marcos
Spudmn
Post
by Spudmn »
Marcos
What components should I use on the PLL.
The BOM says 3.3nf 330pF and 3.9K
Your notes on the schematic say 27nf 2.2 nf and 1K
nitrousnrg
Post
by nitrousnrg »
All my boards used:
3.3nF
220pF
3.3kohm
I didn't had the correct values to build the PLL as I wanted (with a sligthy tighter bandwith)
Marcos
Spudmn
Post
by Spudmn »
Finally found some time to get back to my Puma build.
Marcos How accurate to I need to be with the PLL components. There are now 3 different combinations of components for this part of the circuit.
I am having trouble finding a 3.3nf but I do have a 2.2nf, Will this do?
nitrousnrg
Post
by nitrousnrg »
Check the datasheet, page 1271. The datasheet itself did a fairly rough approximation, so you'll be fine.
The other capacitor will have to be between:
2.2nF / 20 and 2.2nF /10
Marcos
Spudmn
Post
by Spudmn »
OK I have a 2n2 for C93 and a 220pF for C94 but I am having trouble trying to work out what R175 should be now.
Can anyone help?
nitrousnrg
Post
by nitrousnrg »
6.8kOhm will be fine. You'll have a loop bandwidth of 30khz instead of 20khz, which is no big difference :-)
Marcos
Spudmn
Post
by Spudmn »
Thanks
Spudmn
Post
by Spudmn »
I now have the Micro soldered on and I am putting together a temporary RS232 interface.
Marcos. there is a Cap C? Near the BDM. Do I need to put this on?
Fred. I can get a Win Laptop. What software should I but on it?
