schematics
Dan
Re: schematics
Post by Dan »
Hello gsune,
RavAGE is probably the most reviewed set of schematics currently available for supporting FreeEMS.
The injector and ignition channels are currently fixed to be shared with PORT T CPU pins, with allowances made in the schematics to utilise CPU PORT B channels once the firmware matures in the future.
The RavAGE schematics are a good reference with respect to what CPU pin is locked to what function, so dont swap them around or you will probably not be supported firmware wise.
The RavAGE schematics are also a 'live' document, so keep an eye on the git repository regularly.
The GIT repository is located here
https://github.com/dvisser/Ravage
Direct link to schematics in PDF form is here
https://github.com/dvisser/Ravage/blob/ ... f?raw=true
All other schematic files in the repository are in Altium Designer format.
If I can be of any further help to you please let me know. Specifically if it is a hardware oriented question you have, this will hopefully help share some of the burden on Fred who is currently overloaded in terms of workload.
Hope that helped.
Dan
gsune
Re: schematics
Post by gsune »
thannnnnnnks you a lot
Re: schematics
gsune, what you should take from the above, is that you should expect to work closely with the rest of the active members if you want success. Don't expect to just use it, you're just testing for now. If you want a system to just use, get a MegaSquirt or Motec or wait 6+ months.
gsune
Re: schematics
Post by gsune »
ok.
where can i send my works ?
thanks
Re: schematics
