You are most welcome :-)Brian wrote:Thanks for the answers Fred, all much clearer now, especially the 4mA pin limit on the cpu. Thats not much room to play with.
They actually don't spec them as a pin, only as a bank. They spec an instantaneous max of 25 for a pin, but thats not a continuous limit, probably far from it. You could probably get 10mA out of them if the duty on a bank wasn't all that high etc. I have had my CPU lock up solid by over loading the pins on it... I thought I'd stuffed it, but it just latched up solid. All IO pins froze in their current states (= hydrolock and or burnt coils injectors ignitors etc on a real setup...)
My MS2 is setup with 330Ohm resistors straight out to external ignitors with no protection. I'm very unhappy about that and will be fixing it ASAP unless I'm ripping it out in favour of this instead :-) you should be using 1.6k with ms2 or this, and if that isn't enough to drive your load, you need a transistor or IC to buffer it. The vb921 at least requires a firm drive that the MS2 can't safely deliver. Other chips may vary...
