View unanswered posts | View active topics It is currently Thu Feb 20, 2020 6:47 am
Reply to topic  [ 13 posts ]  Go to page Previous  1, 2
lsu 4.9 sensor dead in a week need to figure out why
Its not an issue its an algorithm that vonverts 5 volt to 3.67 volt for stock program for whatever reason
Crome only accepts one input as o2 sensor input
If you re using ostrich.hulog combo theres no other inputs available.
I got the thing calibrated but its much easier to use serial output when im using neptune.
Less issues more accurate readings
Fri Apr 01, 2016 12:13 am
oh goodness, chrome, I have used that horrid of a program before.
well if you do have a working analog input to use my recommendation goes to the AFR500v2 unit.
Wed Apr 06, 2016 1:29 pm
Crome is cheap.
When you got 4 hondas with stock ish motors its best thing
Wed Apr 06, 2016 9:50 pm
