View unanswered posts | View active topics It is currently Tue May 22, 2018 10:02 pm
Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
MS-PNP fail on Mighty Car Mods
Really weird that it fried a power trace while in load mode and cranking. Alternator wouldn't have excited at that point, so couldn't be a spike.
I've not seen inside those boxes, but I'm not surprised at your comments. The latest MS3-"pro" is full of flaws too, and they charge moonbeams for those. And the idiots lap them up...
As for flashing vs ignition, we've got you covered here, that's not a problem with a properly setup FreeEMS unit. And by properly setup, I mean the circuit topology.
+1 to specific boards spun for each PNP platform, take a look at what Dan is doing for the RB25DET in "fledgling designs".
I wonder what became of the PNP in the video. It must've ended up somewhere :-)
Mon Oct 14, 2013 11:58 am
I don't know if this was posted but is possible that they killed the MS1 PNP unit. IIRC you have to pull a certain fuse\relay on the 1.6l miata for the fuel pump and if you don't you backfeed power into the mspnp unit.
Either way the haltech is hundred times better than a ms1 unit and still better than the ms2.
Sun Nov 03, 2013 4:21 am
ivan141 wrote:
I wont pretend to be an expert on MS-PNP hardware.. it really is too hard to tell what goes where on those 4-layer boards and with the availability of proper schematics for the SMD board being what it is at the moment. All I could tell whas that it was a 5 or 12V trace going to a pretty big capacitor (that looked like it was added as an afterthought). BTW, he also made the mistake of not removing a fuse mentioned in the manual when flashing once, which should have fried his coil, but somehow seems to have gotten away without damage.
Personally I feel the design on these old MS1 based PNP's is a disgrace (considering they where sold commercially).
I see wire jumpers soldered all over the place, capacitors soldered in place as an afterthought.
Not sure if there is much that can be done about behaviour when flashing firmware, but I'd at the very least expect some
consideration for robustness to stupid monkey users (known in our line of business as average customers).
I like the idea of a baseboard with an expansion board for PNP use with OEM connectors very much, but how hard can it be
to come up with a baseboard design that doesnt need wire jumpers, or for that matter: with PCB fab costs being as low as
they are these days: why not build a batch of more specific baseboards?
in Terms of flashing the hardware yes there is that issue with coils is how they designed the outputs to the coils to work, causing them to go high while the ecu is on due to the output being held high which would kill coils\igintors.
I didn't have any issue with the jag and freeEMS board when I flashed firmware and left the coils all connected.
Sun Nov 03, 2013 4:25 am
If that's true about death by plugging in a PNP board, then it's NOT a PNP board at all, it's a disgrace. Is this true??? :-/
Sun Nov 03, 2013 8:51 am
Yes it is true
http://www.megasquirtpnp.com/gen1/model ... ection_Two
Under: Installing your MSPNP (READ THIS!!!!)
scroll down to there and you see where they have you remove a fuse 10 amp, very important!
Sun Nov 03, 2013 1:44 pm
Wow! :-/ Can't blame the Ozzies for that, really. Not very PNP if it self destructs with a dead stock car IMO.
Sun Nov 03, 2013 4:52 pm
