My MS-II Mircrocontroller (marked MC9S12C64CFAE) is very very hot and have burning smell when power is turned on.
Can I just buy a same Chip, replace,and  then use the downloader to install the firmware?
or there is any specific tool I need for repairing?
Thanks for your help in advance.
						How to repair the MS-II Microcontroller
Re: How to repair the MS-II Microcontroller
My first thought would be that you must have something shorted out. You should see if you can find the short or you'll likely burn up another chip.
I'm not all that familiar with the MSII, I believe you can replace the chip and re-burn the firmware. However I have no idea how to get the initial firmware installed. May require a separate programmer, or it may have an ICP (In Circuit Programmer).
Good luck.
Good luck.
You need a BDM programmer and need to install the serial monitor. This has been asked (and answered) before on the msefi and msextra forums. They even provided the serial monitor code on a recent post on msextra.
The main issue is why is your CPU getting hot. Did you put 12V on Vref? That would be one way to burn the chip. Make sure that everything is fine with the main board before replacing the CPU since this is not a trivial task for most people.
By the way, the best place to ask these types of questions is on the msextra forum.
Jean
Jean
Thanks for your help.
Exactly, I had sort our my short problem: Stepper motor driver IC Power jumper wire broken and touch the VCC.
I will follow your direction.
The reason why I am interested in discussing here is that "you guys are here".
Thanks again.
Thanks again.
