Self learning (I need guideline)
Author |
Message |
Joined: Tue Jan 15, 2008 2:31 pm Posts: 15380 Location: Home sweet home!
Ideally need more than that, coolant and air temperature sensor details, TPS min and max values, wideband profile, MAP sensor model/range/extremes, etc.
Thu Aug 15, 2019 10:29 am |
amatt
I dig out some setting in my TS running with MS2 for this engine.
TPS:- Close adc count- 205 Full adc count- 999
Coolant:- -40C - 100490 ohm 30C - 1875 ohm 99C - 125 ohm
Bias resistor value - 2490 ohm
IAT:-
same value as coolant
Map sensor:- MPX6250A
Engine: nearly 1800cc
Injector size: 210cc
Trigger angle offset: -5 (this value is in TS, if it can be figure it out in Emstudio, please ignore)
Wideband: Innovate MTX, but not attach yet. Just view at it gauge, and do tuning.
Thanks.
Amatt
PS: Should I start a new topic?
Thu Aug 15, 2019 4:25 pm |
amatt
Fred wrote: No, those windows tools are way out of date and I think not compatible with latest source.
You may be able to use that image and get a running setup, but there are newer firmware versions available that I could build for you that will give you a better experience.
EMStudio, Linux only, limited availability, just a bunch of bug fixes and tweaks to suit latest firmware. EMStudio without the fixes is pretty buggy.
What OS are you on? Any update? pre-compile S19?
Thu Sep 12, 2019 3:22 am |
Sorry man, life's been kicking my arse recently in 3 different ways.
New topic, yes, start a thread about your car in users' rides and post some pics and details of the car and engine and sensors etc. And we'll go from there.
Link back to the first post where you started to get serious in this thread, from the new one, and from this one to the new one, too.
Cheers!
Fri Sep 13, 2019 10:45 am |
Who is online |
Users browsing this forum: No registered users and 1 guest |
