ms2 extra ignition
Re: ms2 extra ignition
jsmcortina wrote:It had been reported a little while back that there was an issue at higher rpms if a spark output "landed" on a tooth edge. The CPU was busy handling the tach-in interrupt and the spark was delayed. At the time we didn't have a solution. Recently Ken came up with an idea to reduce the effect which I have implemented. My bench testing at ~8000rpm shows a possible worst case delay before of ~3degress which now looks to be <1degree. However...
PLEASE PROCEED WITH CAUTION! This is a small but significant change to the core spark output code. If you observe any oddities during testing, get off the throttle immediately !
http://msextra.com/forums/viewtopic.php?f=91&t=44952
Retest! :-)
IF you can be bothered! :-)
Dan
Post by Dan »
what junk. why bother with this inferior EMS in the first place.
To replace MicroLebs? :-)
EssEss
Post by EssEss »
My dev board for this platform is long gone.
One of these days, after my move in the next month, I swear FreeEMS is up for some testing/exploration.
Oh fuck! :-o
Can you start with comms? :lol:
