Because development resources are scarce and we intend to do everything, and I mean everything properly down the finest detail, the number of input styles supported will initially be low.
To start with I intend to write code to support 36-1 with or without a cam sync pulse. I have one tester who has this setup, and it is by far the most common type. It is also what I intend to use FreeEMS for when I get back to NZ.
What comes next on the list will depend entirely on what that trigger type supports (at the very least wasted spark/semi sequential) or doesn't and whether or not someone is going to actively alpha test that code in the short term future.
Two main types of post are welcomed,
A I have this and I want to alpha test it with you
B I would one day like to see this present as an option
Posts in this thread of the A type should include sufficiently detailed public domain information about or teeth etc, which edges are reliable, whether they are VR, Hall, or something else, etc. i.e. enough detail to implement the functionality in the code.
Posts in this thread of the A type should also state what your personal intentions are. i.e. :
- Whether you have a running vehicle with this type of trigger on it
- Whether you have an xdp512 and support circuits at you disposal or are planning to order soon
- What level your electronic skills are at (testing at this stage will involve building or adapting boards either on strip board or designing and printing your own)
- What level your DIY EMS skills are at (anyone with good MS experience should be fine in this regard)
- How much time you think you can throw at testing (being alpha there is every chance that stuff wont work and will need multiple testing sessions)
- What level your C code skills are at (the ability to diagnose things and retest them youself with changes is a bonus for sure)
And, of course, discussion/banter about the things mentioned which is on topic is also welcome :-)
EDIT : Have a look at the wheel analysis ods file in the docs directory of one of the later releases to see what has been thought about so far.
Admin.
