posting these by request, they are all motorbike pickups. They all bolt directly to the crank.
This is a Yamaha TRX-850 timing pickup Left is modified to 36-1 spec, the one on the right is standard, which is 4 teeth, 1 tooth is long, its exactly 45deg long. The engine is a 2cyl parallel twin fired at 270deg. Basically its a v-twin.
This is a selection of Honda units. The one on the far right is a 12-3 which is common. Its for a VTR1000, or commonly called a RC51. Its a V-twin, 2 cylinder. The other 2 are as yet un-identified, BUT i suspect the middle one is a honda VFR800, which is a V4, 800cc engine. Im fairly positive it has 2 sensors, one on each side of the crank, and each sensor runs only 2 cylinder events. Basically its a pair of V-twins stuck together.
Honda Goldwing / Valkyrie (GL1500). ~1600cc flat 6. Yes, a 6 cylinder bike.
3 various yamaha units. Its dependant on what year the bike came out. But yamaha mostly use the same one across their range, and just tweak the ECU to match it.. 18-1, 24-2 are common units. Most of these bikes are inline 4cylinder engine
http://img707.imageshack.us/i/image008ex.jpg/
kawasaki ZX12, and heres a blurb i got on it:
The timing wheel is shown with cylinders 1 and 4 at TDC. You can see that the sensor is mounted 10 degrees off the TDC line. This means that when tab 8 is directly in front of the sensor the crank is at 10 BTDC. Which is the idle timing advance specified in the manual.
In looking at the software I find that actually tab 7 would trigger the Coil timing calculation. It would pull the value from the coil maps shown above and then subtract it from 67.5 degrees. The idle figure, and lowest value shown, in the map is 64. As explained above this is a fraction of 90 degrees, 256 being 1/1 and 64/256 = 1/4 = 22.5 degrees.
Now when tab 7 is in front of the sensor 67.5 degrees in the future is half way between tabs 1 and 8. Of course 67.5 - 22.5 = 45 degrees. 45 degrees after tab 7 is in front of the sensor would be tab 8 in front of the sensor or as stated above 10 BTDC.
So the formula ends up being 12.5 - ((mapvalue / 256) * 90) = degrees BTDC
`98 - 01 kwak zx6 (inline 4cyl, its identical to zx10 and quite possibly some ZZR's too.
Kawasaki, but not sure which one.. Possibly a GPZ 96 model. Same as the yamaha unit as above.. 4cyl engine
Suzuki gsxr1100 and bandit rotor..
Honda NSR250 MC28 2 stroke v-twin.
After doing a fairly big search to cover many bases. It seems the 12-3 and the 4+1 (4 teeth, 1 long tooth) are the most common. Its quite surprising how many bikes they are on. NipponDenso and Mitsubishi electric made these and sold them as a "complete kit" to the 4 main motorcycle manuf's in japan. Euro (triumph, ducati, MV, KTM, BMW, etc..) are all different again..
ND / mitshi would hard program the ECU on the bike to the customers requirements, and thats it. It was fixed. Never to be adjusted or screwed with again. Its why I think having these included would be a HUGE benefit to many people.
I hope this information can help.
