Circuit REQUIREMENTS For ALL Decoders!
Locked
Please note that ALL decoders are ONLY guaranteed to work correctly when passed through an inversion circuit on the way in. The standard circuit for this is a variant of the max99xx chip series. LM1815 can also work for VR stuff and a simple NOT gate can work for hall/optical stuff if you are happy that the signal is clean.
Likewise, if you're writing a decoder for whatever platform, and you should probably just tell me that you need one, I can do it faster, then make sure it is developed against the correct circuit topology.
Locked
