View unanswered posts | View active topics It is currently Sun Mar 24, 2019 5:38 am
Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3  Next
Bench Test Decoder
The tracker issue:
http://issues.freeems.org/view.php?id=248
Short version:
The decoder produces an extra or part of an extra cycle.
Thu Aug 25, 2011 10:50 pm
Sim, thank you very much, stellar effort there!
MegaTunix now has a UI available for testing the tester. If anyone wants to give it a shot, please report back to Dave about it in the appropriate forum section (not here).
Sat Aug 27, 2011 9:56 am
http://issues.freeems.org/view.php?id=194 - issue closed, thanks Dave! :-) I tested it last night with a portable scope and it does indeed work nicely!
Sun Aug 28, 2011 3:27 pm
http://www.youtube.com/watch?v=Ec80QrdIrB0 - Some real world use in Canada by Sim, cool! :-)
Thu Sep 01, 2011 10:39 am
Tonight I added a lock out that rejects requests if already running and a stop packet so you can turn it off from a UI and a jog/bump/inc packet so you can make it run just a little longer, nice! :-) Dave won't put them in MTX until I document, which is fair enough, but it's a low priority at this point.
Wed Oct 12, 2011 11:37 pm
Dave did some work on this recently and added stop and bump functions. He also added button lockout logic and a timer that increments accurately with the bump button and finishes at the same time as the test does. Nice!
Thu Nov 24, 2011 4:02 am
My JimStim is broken, and I can't get any noise from Jean or Jerry, so I added a hacky missing tooth mode to the bench test decoder to allow me to use one freeems to test another...
Details on RPM performance are in my diary thread here: viewtopic.php?p=20967#p20967
This mode is selected by setting one, and only one, PW Source value to 3. More generates and error, larger values under the cut off generate an error, less does what it used to.
Tue Dec 20, 2011 2:41 pm
Upgraded the hack for variable RPM and got John to help me write a little utility to control it:
Get the util from:
https://github.com/johnhowe/Lacerated-Pempheridae/ (once he brings it up to date in a few hours, my fork before that)
Bench test firmware is all you need, outputs are on PT2 and PT3.
Thu Dec 22, 2011 8:22 pm
Upgraded the hack for 0 to 5 missing teeth, works perfectly in testing so far. Place the 3 in the slot with then number of the number you want missing. 0 through 5. Nothing much more to say on this.
Fri Jan 27, 2012 10:23 pm
2 things:
1) LP + BT FW need 5beb5d6b4 & 0fc4cbc87 or newer, respectively, or both nee d to be older.
2) If it won't go to a low enough RPM for you, you can lower the speed of the firmware by changing the value of PTPSR in init.c near line 545. Useful for low res simulations such as Andy's and Presto's and Mine.
Fri Oct 26, 2012 6:55 pm
