View unanswered posts | View active topics It is currently Fri Jan 18, 2019 4:34 am
Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3
Bench Test Decoder
I just tweaked the BenchTest decoder to produce a J Series pattern. If you want the same functionality, change this:
Code:
      // Output the sync pulse only once per "engine cycle"
      if(KeyUserDebugs.currentEvent == 0){
To this:
Code:
      if(KeyUserDebugs.currentEvent == 0 ||
            KeyUserDebugs.currentEvent == 4 ||
            KeyUserDebugs.currentEvent == 8 ||
            KeyUserDebugs.currentEvent == 12){
And get this:
This works for 2245b23028d877fa2002f1886522168db24429aa or later. It was completely broken for a few commits before this, unsure how many.
The command to produce the above output is:
Code:
./pempheridae2 -r -i 1 -m 0 -t 12 -j 400 -k 500
However only the -m 0 and -t 12 are important, the rest you can do what you like with.
Tue Apr 30, 2013 10:54 am
For those that haven't seen it, or can't get MTX to not crash, here's the BenchTest panel:
Mon May 06, 2013 7:50 pm
Updated earlier post to reflect current payload ID and prevent further errors. The final reference should always be the source, Luke. My mistake, now made more difficult to make again.
Fri Aug 09, 2013 5:36 pm
