View unanswered posts | View active topics It is currently Thu May 23, 2019 12:28 pm
Reply to topic  [ 14 posts ]  Go to page Previous  1, 2
Mitsi 4g63 DSM/Evo and NA Miata 4and2 CAS Decoder
http://issues.freeems.org/view.php?id=110
Done tonight, with a slight hack that I'll clean up when I get a chance. On a temp branch until then. Needs an angle tweak too, and more of the sync points implemented, but this is good enough for the time being. Sync inside 360 degrees max as is, syncing only on inner track.
Mon Sep 03, 2012 10:36 pm
Upgraded to 4 sync points from 2. Enjoy! :-)
Tue Sep 04, 2012 11:25 pm
This is the annotated version of the diagram with event numbers as per the code.
This decoder is now pushed and available in the dev branch, FYI.
Mon May 06, 2013 4:40 pm
First one shows that you might wait up to 4 edges before you get sync, depending on engine position when you hit the key:
Second one shows the states and actions and so forth, excuse the crappy colours:
Mon May 06, 2013 4:57 pm
