Hi Fred and every body else in the forum.
Just a bump to remind you that I am waiting as you recommended.
Juan
Honda K Series Discussion
Re: Honda K Series Discussion
I've asked someone with some first hand K-Series knowledge to post what he knows. Fingers crossed that he does :-)
I think since last time I wrote this which you should probably read: viewtopic.php?f=41&t=1699
I am running a K20 myself on modified MS1-extra firmware that I wrote to support the 12+1 trigger. I am not using cam sync in my set up but firing wasted spark instead and with no VVT, I replaced the VVT actuator with an adjustable static timing pulley from Toda Racing in Japan. I can still tell you a few things about the triggers on this engine.
Pictures of trigger wheels, the one of the cam wheels is not very good but it shows the general idea.
http://i.imgur.com/Zi2Q4.jpg
http://i.imgur.com/uwyrs.jpg
The inlet cam has a 4 tooth wheel bolted to the back of it, evenly spaced, equal width teeth so it is of no use for engine phasing, used for cam angle sensing only.
The exhaust cam has a 4 tooth wheel bolted to the back of it, one edge is evenly spaced IIRC but the teeth have different widths so this is the input you need to use for phasing.
The crank wheel has 12 evenly spaced teeth and one extra tooth that comes 10 degrees after TDC on cyl #1/4.
FREDIT: "they are all hall" re sensors.
Reason: Add sensor info.
OK, so the phasing thing might be subtle but the crank wheel should be fairly straight forward to do once my time based sync stuff is solid. Right now it sucks... but I'm working on it. Once it's solid I'll take a crack at this too :-)
Well I knew that right now might be hard I just wanted to let you know that I am still wating and almost daily reading the updates to firmware and hardware. I am ready when you are
. Baldur I know of your project but there are more details
How did it do for the the seasons, did the transmission that you are using hold more that the one from the vw engine. and you disable vvt because for you is to slow acting but is the vtec still in use? Last with the custom static timing pulley did you notice any lost in performance compare to the other engines that I know you have tuned.
Juan
Juan
We wrecked two engines this season, turns out the stock Honda connecting rods don't like making 400hp and they like nitrous even less, these were stock engines because we didn't have the time to build an engine with stronger internals. The vtec is still in use, just controlled by the ECU to switch on at a certain RPM. I have not tuned an engine like this with a turbo before so I can't comment on the relative performance, but of course the VVT has no effect on peak power, it only broadens the power band slightly.Jpolanco wrote:Baldur I know of your project but there are more detailsHow did it do for the the seasons, did the transmission that you are using hold more that the one from the vw engine. and you disable vvt because for you is to slow acting but is the vtec still in use? Last with the custom static timing pulley did you notice any lost in performance compare to the other engines that I know you have tuned.
Juan
