Vband weld is probably 20mm from the face.
I ordered the air filter based on it's advertised dimensions as the largest that would fit and was surprised find they were accurate when it dropped in.
Priority is to dial in injector dead time and tune.
To-do list looks like this now:
• tune iinjector dead time
• Improve wiper performance- swap in other motors and check auto park
• modify 5spd shifter to fit center console
• Front spoiler - victim of launched road debris
• Alignment: *slightly* wandery above 120 in a dead straight line
• Overrun rattle around 2500 RPM- PPF?
• RX7 FC transmission swap/PPF adapter & driveshaft
I looked into the wiper issue. When I shut them off they don't auto park- just stop. That means something is up with the motor- fortunately I have three more on the shelf, so that's just a matter of swapping them out. Of course they could all be bad.
With the engine pushed back in the chassis, the shifter won't stay in 2nd, 4th or 5th because it hits the console. I'm going to section it and move the top part forward so it's offset by enough to avoid the interference.
Alignment doesn't bother me at the moment, so that's low on the list- and I suspect it's because the front has 0 toe.
I may not address the overrun rattle because it's a constant reminder that I need to get the FC transmission adapted and installed.
