HotCat's Citroen ZX TU5JP/K engine is running (18th)
HotCat
Post by HotCat »
Owner: Yu Zhou
Make: PSA
Model: 01 Citroen ZX 7160AXC
Engine: PSA TU5JP/K, SOHC
Capacity: 1587cc
Wheel pattern: Crank 60-2
VR sensor offset: 246 degree
Controls: Both fuel & ignitions, replace OEM ECU completely
Hardware: I design it
Repository: https://github.com/HotCat/FireCat
Description: Special design to reuse OEM box and harness, onboard IC ignitors
ECU build thread:
viewtopic.php?f=54&t=1981
Videos:
This is the most terrible effect I've every made. I decide to reproduce it this week if I can find an assistant
http://www.sendspace.com/file/utmyia
photos:
Re: HotCat's Citroen ZX TU5JP/K engine is running(18th)
You're a hero! First in China! First of millions, perhaps? :-) Well done, mate, and thanks for your patience and determination!
Re video, we need to get you some server/upload space so we can youtube it for you! Let me know if you can find a way to upload the raw file(s) across the G-firewall, if not, we'll sort something out for you. You could use unix "split" to chunk it into 20meg blocks and email them to me if you want :-)
masterkorp
Re: HotCat's Citroen ZX TU5JP/K engine is running (18th)
Post by masterkorp »
Congrats!
I can provide hosting for the upload.
Dan
Post by Dan »
Congratulations! (love the fire extinguisher in the photo too) :-)
Hentai
Post by Hentai »
Anyone else notice the CatSquirt on the board?
DeuceEFI
Post by DeuceEFI »
Congratulations on getting your board design sorted out HotCat!
And welcome to the first 20 FreeEMS vehicle list :-)
:D
HotCat
Post by HotCat »
DeuceEFI wrote:Congratulations on getting your board design sorted out HotCat!
:D
I have another GM 3.0 v6 engine on my 99 Buick Regal, I wish to do ignition using FreeEMS because the engine can not output enough power when the RPM is above 1600, the stock ECU ignore the 24x crank input but calculate the engine RPM by 3x output from ignition module. I think this is the performance bottle-neck. What's your opinion? I found it is difficult to crank the engine by hand to mark the timing mark
This should be the next FreeEMS powered car in China
HotCat
Post by HotCat »
Fred wrote:Re video, we need to get you some server/upload space so we can youtube it for you!
I've already use sendspace to share my video, the the video was badly taken, I must reproduce it on daylight
JareeB
Post by JareeB »
congrats!!
plans to build a 300whp turbo ford ranger with a 2.3l engine the ford lima!
current rig: 1994 ford ranger 2.3. good platform for my almost complete turbo engine. a237 cam, stock t3 turbo, ported and polished head. just needs some mangement!!
