Owner: Justin
Make: Mazda
Model: Miata \ MX5
Engine: B6-ZE
Capacity: 96ci \ 1.6l
Power Adders: turbocharger T3 60 trim
Hardware: Jaguar A3
Videos will be up shortly.
Startup of the vehicle running FreeEMS\Jaguar
http://youtu.be/ZsdH882TuxU
Idling and some rev action with flat 10 table
http://www.youtube.com/watch?v=2DRq3ZD2 ... e=youtu.be
This has been sponsored by DeuceEFI, Fred, FreeEMS, as well as many others down the road that have helped.
<masterkorp> also its a very long tradition to do a burnout
I don't care for burnouts so instead I shall get a video of me doing a long pull or something of that nature
Hentai's 1992 Mazda Miata (15th)
Re: Hentai's 1992 Mazda Miata (15th)
Congrats, man! :-) Onwards and upwards!
From skype: starts almost instantly :-) Just wait till the decoder is fine tuned and the engine tuned :-)
Added videos
malcom2073
Way to go!
Cool, Another engine running on a Jaguar PCB and FreeEMS
Congratulations, Hentai !!
The car will be now weened off the megasquirt. Now to cover wiring and enclose the jaguar and remove the megasquirt.
To make flashing the ecu easy I may run some wiring out to the ecu case and have a 2 pin connector that connects to a switch on the dash somewhere that can be flipped on and off to enable easy flashing.
I haven't tested yet, didn't have time, went to a local drag event to help support the alcohol drag car owner but I am planing to test stock igintion pieces to figure out if they work as well, I bet they will.
Love your work and I absolutely epicly lol'd at this
LOLHentai wrote:I shall get a video of me doing a long pull
Make it a momentary switch (unless you want to use it like an immobiliser too) and also externalise the CEL LED for feedback. Don't try to use the one in your dash just yet, though. Just make it separate.Hentai wrote:To make flashing the ecu easy I may run some wiring out to the ecu case and have a 2 pin connector that connects to a switch on the dash somewhere that can be flipped on and off to enable easy flashing.
LOL @ Dan.
