If you run something with FreeEMS, please post here!
Posted: Sun Mar 06, 2011 7:41 am
				As the title says, if you've got something running, a bench rig for injectors, a 3 cylinder daihatsu, a 12 cylinder ferarri, a lawn mower, anything, post a thread here with some details, pics, vids, whatever you can! This section is a for-fun show off section to be proud that you are some of the first running FreeEMS on your ride! If you want to do an engine or chassis or body build thread, do that in user rides, if you are doing an ECU build thread, do that in the appropriate section above. You may cross link between any or all of them, or not, at your discretion.
For engines, please put your placing in the thread title. See the existing threads for examples!
Thanks!
Thanks!
