View unanswered posts | View active topics It is currently Fri Apr 16, 2021 4:20 pm
Reply to topic  [ 4 posts ]
Causes Of CPU Resets
Hello world,
I was just about to tell someone what the possible causes are, and thought I'd put it here for others' reference, too.
Reset Line Pulled Low
If the reset line is pulled low, even briefly, the CPU will hard reset. On the Jaguar (0.7-alpha), C6 and R5 are responsible for preventing this from occurring due to noise. Therefore this is unlikely to occur.
Power Supply Briefly Removed
This is the same as turning it off completely for a longer time and then back on again. But quicker. Can only really happen with a bad connector or connection or internally broken wire.
Power Supply Quality Issue
A noisy 5V rail can cause the CPU to lockup or reset. Noise can get here in several ways:
1) Sudden load/unload
2) Oscillating regulator
3) Extreme 12V supply variations
Software Initiated Resets
The firmware has a facility to be told to reset by external software over the serial comms line. The chances of this happening due to noise are extremely low indeed. The firmware has many independent mechanisms to reject bogus packets. Accepted packets of all types must be absolutely perfect.
Hardware Initiated Resets
The MCU has a facility to reset the device if it's not functioning properly. I have this in place on my car, however no other car I'm aware of has this. The version I have is not of sufficient quality for general distribution, hence not shared.
System Reset Generation
System reset generation from the following possible sources (My comments in bold):
  • Power on reset - normal behaviour
  • Low voltage reset - Low quality supply, possibly during cranking with bad battery
  • Illegal address reset - Corruption or bad code
  • COP reset - Software controlled or firmware failure (with future fw)
  • Loss of clock reset - We don't meet conditions for this. Instead we self-clock and then recover with tell-tales in the log.
  • External pin reset - First thing in above list
I may have missed some, and reserve the right to edit the above over time. Feedback welcome, comment below!
Wed Aug 20, 2014 10:22 pm
I posted this because Josh is experiencing 10 second periodic resets of his CPU with his engine off. His car is devoid of electronics and noisy devices of any kind. The only thing capable of generating noise is the ECU-engine combo, and possibly a few relays which aren't being periodically activated in sync with this issue. Additionally, he says that it's solid/good once running. Any ideas are welcome as the above fails to explain this behaviour.
Wed Aug 20, 2014 10:24 pm
Attached is a log created with my SDLogger attached to the Jaguar 0.7-alpha that I use in my S10, while on my bench.
When I look at the tempClock, clockInMilliSeconds and clock8thMSsInMillis with OLV I'm not seeing them fall to zero before rising to the maximum value for the variable.
I have log files created with EMStudio as well, but I only see weirdness with these three values during EMS interrogation when EMStudio is first started. I have also attached one of my recent test drive in the S10 created with EMStudio in which I see the clock "weirdness" during the interrogation process.
Or maybe I'm missing what I should be looking for?
If I can reproduce the conditions in which others are seeing the clock resets I can look further into why they are happening.
File comment: Jaguar 0.7-alpha engine startup, warmup and drive down the road and back.
2014.08.20-19.48.13-S10-Jaguar-0.7-alpha-Test-Drive.bin.zip [712.97 KiB]
Downloaded 663 times
File comment: Jaguar 0.7-alpha removed from the S10 on my bench.
LOG00307-Jaguar-0.7-alpha-Check-For-Resets.BIN.zip [197.19 KiB]
Downloaded 690 times
Thu Aug 21, 2014 2:13 am
Very very easy to grab a log of a reset. Just turn off the key mid log for a second, turn it back on, log for a bit more. Then review.
Thu Aug 21, 2014 6:22 am
