Volvo 60-2 +1
For people running FreeEMS to discuss it and ask any questions about using and adjusting it.
em_knaps
Volvo 60-2 +1
Post by em_knaps »
As encouraged by Fred and perhaps for is explicit enjoyment I am going to run a volvo 5 banger turbo with Freeems.
Trigger is as the title would suggest:
crank 60-2
cam 1
This is what I have observed thus far as far as trigger timing as far as cyl#1 is concerned:
TDC #1 is slap bang in the center of T12 (tooth 12) so T1 is at 72deg BTDC
cam signal consists of a hall sensor and one tooth that is roughly half of the wheel
cam tooth starts at T29 (102deg ATDC)and finishes one crank revolution later.
is this trigger type catered for within the current decoders?
Requests/demands for further information are expected.
Standing by.
Re: Volvo 60-2 +1
Yeah, it's covered, but performance is poor. Set rev limiter to 2500 or 3000 at the most until further notice. As for the cam sync and seq/COP, that's not covered yet, but I could hack it in for you pretty easily.
em_knaps
Re: Volvo 60-2 +1
Post by em_knaps »
Would running this engine with this trigger setup be productive as far as development of the high count missing tooth decoders is concerned?
If the origin of the performance issue is known and just requires time to improve I could do one of a few things to make this engine run
without the 60-2.
I could reduce the number of teeth.
I could put another toothed trigger in place of the dizzy with a more appropriate number of teeth
or something else that may pop into my head in the coming weeks.
excellent..
Re: Volvo 60-2 +1
Yeah, the issue is known. A 12-1 or 24-1 in the dizzy would work nicely for you, assuming a clean drive and proper signal handling.
em_knaps
Re: Volvo 60-2 +1
Post by em_knaps »
Rightio, I shall come up with something cunning. a 12-1 or similar on the cam would negate the use of the single tooth cam sensor which will make mods to the old slater ecu easier.
Im going to use those bosch bips to control the coils.
In a box away from the ecu though.
rightio, time for some trickery.
hmm. a 1UZ crank trigger wheel mounted to the old dizzy drive pop's into mind...
time for a hand shandy then some sleep I think.
Re: Volvo 60-2 +1
LOL @ public admissions of private self-pleasure.
What about a 24 tooth from a typical toymotor dizzy, with one removed.
em_knaps
Re: Volvo 60-2 +1
Post by em_knaps »
I think I have a solution.
I need to put a manual flywheel on it so when I get one I'll chew some of the teeth off and run a crank and cam trigger.
is a set number on the crank better than a missing tooth arrangement?
seeing as i have a cam trigger for every 720deg
hmmm, just gotta find a flywheel..
meow
Re: Volvo 60-2 +1
Right now, yes. How many are you thinking?
em_knaps
Re: Volvo 60-2 +1
Post by em_knaps »
I was thinking 20
as i can just continue the missing 2 that the flywheel already has, just remove ever other two
I my even be able to chop the flexiplate teeth to suit
Ill give it a go today and see how nicely they let me remove them.
Incase im not clear. it has a flexiplate, with the 60-2.
but I need a flywheel. but for now ill see if i can mod the flexiplate.
Re: Volvo 60-2 +1
That should work well. Too high would be risky, too low not accurate enough. I'll move this thread to user support after your next post.
