Author |
Message |
andg
SOT-223 - Salvaje
Joined: Thu Apr 18, 2013 3:21 am Posts: 144 Location: Portland OREGON
_________________Code: {url: andrewgauger.com, skype: andrgaug, email: andg@andrewgauger.com, car: 25, fb: facebook.com/DonatoArrighi, github: andg.github.io, assets:https://s3.amazonaws.com/3400}
Fri May 10, 2013 6:47 am |
andg
SOT-223 - Salvaje
Code: andg:freeems-vanilla andg$ git branch * master andg:freeems-vanilla andg$ git checkout dev error: pathspec 'dev' did not match any file(s) known to git. andg:freeems-vanilla andg$ git checkout -b dev Switched to a new branch 'dev' andg:freeems-vanilla andg$ git pull origin dev remote: Counting objects: 186, done. remote: Compressing objects: 100% (113/113), done. remote: Total 143 (delta 105), reused 51 (delta 18) Receiving objects: 100% (143/143), 29.42 KiB, done. Resolving deltas: 100% (105/105), completed with 38 local objects. From https://github.com/fredcooke/freeems-vanilla * branch dev -> FETCH_HEAD Updating b0cd375..dc9dcc3 Fast-forward .gitignore | 7 ++- Makefile | 4 ++ bin/testclibuilds.bash | 4 +- docs/git/config | 33 +----------- src/main/Makefile | 20 ++++--- src/main/data/tables/axis/Deuces3100-Load.h | 56 ++++++++++++++++++++ src/main/data/tables/axis/Deuces3100-RPM.h | 62 ++++++++++++++++++++++ src/main/data/tables/axis/ScavengersMiata-Load.h | 54 +++++++++++++++++++ src/main/data/tables/axis/ScavengersMiata-RPM.h | 59 +++++++++++++++++++++ src/main/data/tables/ign/DeucesS10Timing.h | 51 ++++++++++++++++++ src/main/data/tables/ign/ScavengerTiming24RPMx19Load.h | 60 +++++++++++++++++++++ src/main/data/tables/lambda/DeucesS10Lambda.h | 61 +++++++++++++++++++++ src/main/data/tables/lambda/ScavengerLambda24RPMx19Load.h | 60 +++++++++++++++++++++ src/main/data/tables/ve/DeucesS10VE.h | 53 +++++++++++++++++++ src/main/data/tables/ve/ScavengerVE24RPMx19Load.h | 60 +++++++++++++++++++++ src/main/decoderInterface.c | 16 +++++- src/main/decoders/EvenTeeth-Cam-4and1.c | 49 +++++++++++++++++ src/main/decoders/GM-LT1-CAS-360and8.c | 9 +++- src/main/decoders/JSeries-12CrankWith6-2Cam.c | 25 +++++---- src/main/decoders/MitsiAndMazda-CAS-4and1.c | 398 +++++++++++++----------------------------------------------------------------------------------------------------------------------------- src/main/decoders/MitsiAndMazda-CAS-4and2.c | 282 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ src/main/decoders/code/EvenTeeth-Xand1.c | 10 +++- src/main/decoders/code/HallOrOptical-Distributor-XofY.c | 6 +-- src/main/decoders/code/MissingTeeth-Either-XminusY.c | 13 ++++- src/main/decoders/inc/MitsiAndMazda-CAS-4and1.h | 2 +- src/main/decoders/inc/MitsiAndMazda-CAS-4and2.h | 83 +++++++++++++++++++++++++++++ src/main/inc/FixedConfigs.h | 6 ++- src/main/inc/constantsLibrary.h | 5 ++ src/main/inc/counterTypes.h | 6 +-- src/main/inc/decoderInterface.h | 76 +++++++++++++++++---------- src/main/inc/systemConfig.h | 9 ++++ src/main/initialisers/CHTTransferTable.c | 4 ++ src/main/initialisers/FixedConfig1.c | 47 ++++++++++++++++- src/main/initialisers/FixedConfig2.c | 31 +++++++++-- src/main/initialisers/FuelTables.c | 37 ++++++++++++- src/main/initialisers/IATTransferTable.c | 2 + src/main/initialisers/TimingTables.c | 18 +++++++ src/main/initialisers/TunableConfig.c | 18 ++++++- src/main/realtimeISRs.c | 2 +- src/main/tableLookup.c | 13 ++--- 40 files changed, 1334 insertions(+), 477 deletions(-) create mode 100644 src/main/data/tables/axis/Deuces3100-Load.h create mode 100644 src/main/data/tables/axis/Deuces3100-RPM.h create mode 100644 src/main/data/tables/axis/ScavengersMiata-Load.h create mode 100644 src/main/data/tables/axis/ScavengersMiata-RPM.h create mode 100644 src/main/data/tables/ign/DeucesS10Timing.h create mode 100644 src/main/data/tables/ign/ScavengerTiming24RPMx19Load.h create mode 100644 src/main/data/tables/lambda/DeucesS10Lambda.h create mode 100644 src/main/data/tables/lambda/ScavengerLambda24RPMx19Load.h create mode 100644 src/main/data/tables/ve/DeucesS10VE.h create mode 100644 src/main/data/tables/ve/ScavengerVE24RPMx19Load.h create mode 100644 src/main/decoders/EvenTeeth-Cam-4and1.c create mode 100644 src/main/decoders/MitsiAndMazda-CAS-4and2.c create mode 100644 src/main/decoders/inc/MitsiAndMazda-CAS-4and2.h Just finished my c book and with a new understanding of structs I'm going to start to review the codebase again. inc/freems.h wrote: ** @file * * @ingroup allHeaders * @ingroup globalHeaders * * @brief The main project header file * * The central header for all source files to include. This pulls in the * device header, all other shared headers, all global defines, all global * constant declarations, all type definitions and all global variables. Other * variables that are actually in global space but only shared between a few * select files should be placed in the header for the main file that uses them. */ /inc/xgateglobal.h wrote: /** @file * * @ingroup xgateFiles * * @brief C header for assembly xgate functions * * @author Sean Keys * * Because we need to call the assembly flash burning function from C code an * extern function declaration is required to allow successful compilation. */
So funny the first thing I looked here. I next checked out the makefile. I'm also very interested in the EXTERN syntax.
Fri May 17, 2013 3:14 am |
andg
SOT-223 - Salvaje
inc/EvenTeeth-Cam-6and1.c wrote: /** @file * * @ingroup interruptHandlers * @ingroup enginePositionRPMDecoders * * @brief For evenly spaced teeth on the camshaft with a single second input. * * This is suitable for engines such as the GM DIS Wasted Spark Ignition engines * with 3x TACH output which would equal 3 teeth on the crank and equal for * something with 6 on the cam. Sync is provided by the second input from the * CAM 1x sensor allowing a sequential and/or COP/CNP setup to be used. * * @see EvenTeeth-Xand1.c */ This is the decoder that my Grand Am produces with the DIS that has the 7 signals in one rotation of the cam/crank? where there are 6 even signals and one off by 10 degrees. I'm offloading the processing of that signal into the 3x TACH. decoders/inc/EvenTeeth-Xand1.h wrote: /** @file * * @ingroup interruptHandlers * @ingroup enginePositionRPMDecoders * * @brief For evenly spaced teeth on the cam or crank with a single second input. * * Fill out a data reverse header and include this file. Sync is provided by the * second input allowing a sequential and/or COP/CNP setup to be used. * * VR edition with only one edge used! */ I will want a simple but close to the wasted spark implementation in the hardware. Match path through to processor. next to injection signals, as simple as possible.
Fri May 17, 2013 3:40 am |
andg
SOT-223 - Salvaje
decoders/inc/EvenTeeth-Xand1.h wrote: /** @file * * @ingroup interruptHandlers * @ingroup enginePositionRPMDecoders * * @brief For evenly spaced teeth on the cam or crank with a single second input. * * Fill out a data reverse header and include this file. Sync is provided by the * second input allowing a sequential and/or COP/CNP setup to be used. * * VR edition with only one edge used! */ #include "../../inc/decoderInterface.h"[/quote]hmm... it just looks awkward. Code: /** @file * * @ingroup allHeaders * @ingroup enginePositionRPMDecoders * * @brief Objects through which a decoder communicates. * * This file contains the declarations of objects used as a common interface * between all of the different wheel decoders and the main loop scheduler. */ I don't know what to say this is a pretty well laid out codebase. I can find stuff pretty easily. I think I just need to figure out how to implement a really simple hardware. Looking at the Jaguar as a dev/bench board. Reviewing KiCAD drawing, trying to wrap my mind around the basics.
Fri May 17, 2013 4:03 am |
Joined: Tue Jan 15, 2008 2:31 pm Posts: 15380 Location: Home sweet home!
andg wrote: I'm also very interested in the EXTERN syntax. http://issues.freeems.org/view.php?id=821
Fri May 17, 2013 12:03 pm |
andg
SOT-223 - Salvaje
heh, thanks.
Additionally, at the advice of Sean, I started to learn Verilog. I've got the syntax editor in Sublime Text 2 and downloading Xilinx compiler to start to get a feel for the language.
Fri May 17, 2013 6:40 pm |
Who is online |
