Andg support role
andg
- SOT-223 - Salvaje
Andg support role
If you need firmware or system software Doc or write up on or my primitive QC checks against any firmware tool loader, bench tester, or dash ideas you may ponder feel free to bounce them at me if you want a second or fifteenth look at something.
{url: andrewgauger.com, skype: andrgaug, email: andg@andrewgauger.com, car: 25, fb: facebook.com/DonatoArrighi, github: andg.github.io, assets:https://s3.amazonaws.com/3400}Re: Andg support role
viewtopic.php?f=41&t=1608 Sign up here! :-) And/or keep an eye on it for requests.
Also, just thrash the tools and find faults. Sim found this last night, the hard way: http://issues.freeems.org/view.php?id=838
andg
- SOT-223 - Salvaje
https://github.com/AndrewGauger/freeems-vanilla/pull/1
I commented on the pull request.
was the messed up comment here, github stole my whitespace. It was referring to the comment
`'q'` \ /
) .-'"'-.`'q'`
`'q'` ( \ /
) `'p'`
)fred wrote:// Else do nothing, we're running!
How very useful of you! :-) https://en.wikipedia.org/wiki/Ritalin
andg
- SOT-223 - Salvaje
I think of it more as compulsive than attention deficit. You took my balloons. I guess I didn't post the balloons then. Nevermind. I had some ascii art balloons that github messed up so I posed in a code block, or so I though. Later found my balloons in preview on another tab on another computer.
What balloons?
andg
- SOT-223 - Salvaje
I'm trying out
to see if it alleviates some dependency isses.
Fresh 12.04 desktop ubuntu
eMStudio
Fred want's camel
sudo apt-get install build-essential libqt4-dev libqt4-opengl-dev libqt4-opengl-dev qt4-qmake libqwt-dev libqt4-declarative libqjson-dev
successful make. I didn't know the right dependecies so I ran:
Later ran with a fresh vm with this:
user complaint I don't have a search for com port. I have many com ports on this computer and it detected the wrong one. Baud rate should be drop down. camel case is no place on labels, this is user interface. BE SPEIFIC. send delay(ms) is fine. Don't bother with help if you only have an about.
Seemed to have a bug where having a file open and then trying to open it again returned an error that could be handled with just returning.
I finished setting up the mac with this:
sudo apt-get install qt-sdkFresh 12.04 desktop ubuntu
eMStudio
Fred want's camel
apt-cache search glut
sudo apt-get install libglui-dev libmgl-glut5 libmgl-devCode: Select all
sudo apt-get install libglui-devSeemed to have a bug where having a file open and then trying to open it again returned an error that could be handled with just returning.
- * oracle VirtualBox107 MB
* VM from SourceForge 603MB
* extract the package* set up these programs, add machine and start. Login as ubuntu/reverse. Configure Keyboard layoutCode: Select all
brew install p7zip 7za x ubuntu-12.10-desktop-i386.7z mv ubuntu-12.10-desktop-i386 ~/ubuntu cd ~/ubuntu
* instructions on github
* Appended to the notes:Code: Select all
sudo apt-get install libglui-dev git make install
Thanks for testing :-)
I think it's in the tracker? It's on the TODO though. A bit too much work for the gain right now.andg wrote:user complaint I don't have a search for com port. I have many com ports on this computer and it detected the wrong one.
Editable drop down, OK. But on non-linux platforms, it's more flexible than fixed numbers.Baud rate should be drop down.
Good spotting, but "Inter-byte delay (ms)" is what it should say, "send delay" means very little to me.camel case is no place on labels, this is user interface. BE SPEIFIC. send delay(ms) is fine.
Menu is obviously a place holder for more. He could/should bang a URL opener in there for his forum section, though :-)Don't bother with help if you only have an about.
GOOD FIND! More detail, please! BE SPECIFIC. :-)Seemed to have a bug where having a file open and then trying to open it again returned an error that could be handled with just returning.
andg
- SOT-223 - Salvaje
rebooted.
opened terminal
`emstudio`
load offline data
`forbenofflinedata.json`
open
File
Load offline data
Result:
Error loading JSON. Location ID 0x8000 ram mismatch. Tuner isRam value is fale but json has isRam value of false. Unable to finish loading JSON file. Please check your JSON file to ensure it is not corrupt.
Logged, advised this should have been logged as any/any/any platform
opened terminal
`emstudio`
load offline data
open
File
Load offline data
Result:
