Rev Limiter User Advisory
Posted: Thu Apr 25, 2013 5:59 pm
If you have a seemingly noisy RPM signal in your logs, ensure that your rev limiter hysteresis is greater than the variance in your RPM. If not, it will cut in and out too quickly potentially causing harm.
I noticed this while viewing a log of Sim's and spotted his fuel cut limiter in action at the end of most gears. Of course, he has no injection, so no big deal, but the same would happen at higher RPM for ignition. In that particular case, it could be a good thing, but for injection it's a bad thing.
