View unanswered posts | View active topics It is currently Tue Mar 19, 2019 9:18 am
Reply to topic  [ 11 posts ]  Go to page 1, 2  Next
Installing tools
SOT-223 - Salvaje
So I did a writeup from installing the tools on github for my mac
Code:
Fri Apr 19, 2013 9:31 pm
Fink stuff is likely way out of date. I use a native setup that Dave did ages ago. In general macports is the preferred tool set on Mac for everything except firmware, though. Sorry about shitty tool support for non-"32 deb" :-(
Sat Apr 20, 2013 12:13 am
SOT-223 - Salvaje
I will get a dedicated ubuntu machine then. If I understand you correctly it ought to be 32 bit.
Code:
Sat Apr 20, 2013 5:48 pm
A deb or ubuntu VM isn't a bad idea right now, sadly. You CAN use Mac, I do, but the fink package is WAY old.
git clone that git://github.com/djandruczyk/FreeEMS-OS ... uilder.git
I'm on hash 72f519d762619b046cbd1c7a1369ffa2a7f7aaa3, maybe. I have a bunch of variants built on my file system, and just change their path depending on which I want to use.
This doesn't require fink or macports. You will need macports anyway to build QT tools like EMStudio and Sean's loader. Fink may work, but it's been a LONG time since I tried.
Sat Apr 20, 2013 8:21 pm
SOT-223 - Salvaje
Good ol' dependencies:
Code:
andg:mc9s12x-OS-X-toolchain-builder andg$ ./make_OS-X_toolchain
LLVM compiler detected, searching for alternative...
gcc is unsuitable
gcc-4.2 is unsuitable
i686-apple-darwin11-llvm-gcc-4.2 is unsuitable
llvm-gcc is unsuitable
Invalid args, need <all|get_pre_reqs|clean>
Code:
sudo port selfupdate
sudo port install gcc-select
sudo port select --list gcc
This informs me I have:
Code:
Available versions for gcc:
   llvm-gcc42
   none (active)
I'll compile it with llvm-gcc42 for now.
Code:
sudo port select --set gcc llvm-gcc42
I get the same error message and this time I read it more carefully. It mentions gcc 4.2 is unsuitable not that it can't be found. I am trying this:
Code:
sudo port install gcc45
Code:
sudo port select --set gcc mp-gcc45
Code:
looking much better, now running:
Code:
./make_OS-X_toolchain all
measures of sweet success
Code:
Cloning binutils git tree locally
Cloning into 'FreeScale-s12x-binutils'...
remote: Counting objects: 221807, done.
remote: Compressing objects: 100% (40787/40787), done.
remote: Total 221807 (delta 180287), reused 221241 (delta 179721)
Receiving objects: 100% (221807/221807), 75.81 MiB | 1.71 MiB/s, done.
Resolving deltas: 100% (180287/180287), done.
Downloading GCC from seank's repo
Cloning into 'FreeScale-s12x-gcc'...
remote: Counting objects: 16278, done.
remote: Compressing objects: 100% (12179/12179), done.
Code:
Tue Apr 23, 2013 3:48 pm
SOT-223 - Salvaje
Code:
cat README
output of cat README truncated:
Code:
sudo mv toolchain /opt/FreeEMS-Toolchain
export PATH=$PATH:/opt/FreeEMS-Toolchain/bin
Here I've personally elected to mv to a subdirectory of my home directory where /opt = ~/git/freeems
Code:
sudo mv toolchain ~/git/freeems
export PATH=$PATH:~/git/freeems
but that won't survive a new iTerm session, or the whole bash paradigm so I'll have to update what I do in time with this. Besides I'm likely to just write code on this machine anyway, so I may not be doing any uploading of firmware from this directory. I take separate QA and deployment threads like any good engineer.
The first thing that strikes me about this directory is the complete lack of documentation. Even if this is a compiled version I can't navigate it. Just saying--don't kill the msg(r) Here is some of my favorite documentation
Edit: I'm realizing these are the tools to interface with the FreeScale architecture to load the firmware. I will need to modify the code to reflect that this isn't the firmware code but rather the freeems-tools
Code:
Wed Apr 24, 2013 2:07 am
SOT-223 - Salvaje
Next up is EMS studio, the real genius of Free EMS (Just kidding)
Code:
Wed Apr 24, 2013 2:11 am
LOL
You can put that dir where ever you want it. Now that it's built, you should test it. I'm unsure which hash I'm using, you'll need two available, if you want to screw with experimental code. I tend to rename and/or re-symlink for purpose, this is my rather large /opt dir:
Code:
freeair:~ fred$ l /opt/
total 16
drwxr-xr-x  22 fred  admin   748 Jul 24  2012 .
drwxr-xr-x  35 root  admin  1258 Feb 14 23:45 ..
lrwxr-xr-x   1 fred  admin    39 Jul 24  2012 freeems-tools -> freeems-tools.last.old.before.new.hash/
drwxr-xr-x   8 fred  staff   272 Nov 19  2010 freeems-tools.0
drwxr-xr-x  10 fred  staff   340 Dec 21  2011 freeems-tools.1b0f53a.xg.binutils.hash
drwxr-xr-x  10 fred  staff   340 Jan  5  2012 freeems-tools.41909e2.xg.binutils.hash
drwxr-xr-x  10 fred  staff   340 Jan  5  2012 freeems-tools.46ab71b69.xg.binutils.hash
drwxr-xr-x  10 fred  staff   340 Jan  4  2012 freeems-tools.52c0a45d66.xg.binutils.hash
drwxr-xr-x  11 fred  staff   374 Jan  4  2012 freeems-tools.5a1cb92c.xg.binutils.hash
drwxr-xr-x  10 fred  staff   340 Jan  5  2012 freeems-tools.7a5dcd2956.xg.binutils.hash
drwxr-xr-x  10 fred  staff   340 Jan 10  2012 freeems-tools.8bc858c.hash
drwxr-xr-x  10 fred  staff   340 Mar 12  2011 freeems-tools.built.by.f8e2381
drwxr-xr-x  10 fred  staff   340 Sep  8  2011 freeems-tools.c3a0c9a.xg.binutils.hash
drwxr-xr-x  10 fred  staff   340 Dec 30  2011 freeems-tools.c7148660.xg.binutils.hash
drwxr-xr-x  10 fred  staff   340 Jan  6  2012 freeems-tools.final.hash
drwxr-xr-x  10 fred  staff   340 Jan 25  2012 freeems-tools.first.of.daves.new.tools.25.jan.2012.fresh.clone.binutils.daves.repo
drwxr-xr-x  10 fred  staff   340 Jan  6  2012 freeems-tools.goodbye.code.hash
drwxr-xr-x  10 fred  staff   340 Jan  7  2012 freeems-tools.goodbye.even.more.code.hash
drwxr-xr-x  10 fred  staff   340 Jan  6  2012 freeems-tools.goodbye.more.code.hash
drwxr-xr-x  10 fred  staff   340 Jan 15  2012 freeems-tools.last.old.before.new.hash
lrwxr-xr-x   1 fred  admin    39 Feb 21  2012 freeems-tools.no.error -> freeems-tools.last.old.before.new.hash/
drwxr-xr-x  15 root  admin   510 Aug 16  2012 local
NO idea what any of it means, cept a lot of wasted disk space... :-)
Find a hash that can build my master with a clean git status and label that and use it. Sean can tell you which hash to use for his stuff. symlink/adjust path as appropriate :-)
Wed Apr 24, 2013 8:41 am
SOT-223 - Salvaje
Quote:
last.old.before.new
lol. I have the toughest time with making meaningful names for backups
Code:
Wed Apr 24, 2013 8:40 pm
SOT-223 - Salvaje
I went to install the EMS Studio on an old xp laptop that I was planning on using for tuning. I went to EMS studio downloads and clicked on the first link to download. The install took all of 30 seconds, and suddenly I was ready to interface with firmware. This was the easiest thing yet that I've done on track to setting up my car. I had spent about 10 minutes on #freeems-ot on freenode IRC chatting with the developer about the implementation I had intended with the greatest respect I could imagine a developer providing a user. Fred has been helpful with requirements but Mike was very open with his use, and encouraging. There was no confusing questions for setting up EMS Studio that I had to think twice about, and the tool was installed to the start menu. The tools opened as expected and informed me that the serial interface wasn't hooked up, as I expected.
Code:
Sat May 04, 2013 3:21 am
Users browsing this forum: Baidu [Spider] and 1 guest
