Good morning, everyone.
It has long been watching this forum and I'm starting to build their own engine management system.
Recently a reason why it is worth to finally take charge of this project - I bought a '84 Maserati Biturbo 2500 with carburetor.
As the name suggests, the car has two separate turbochargers on both sides of V6 engine.
If time permits, I would install FreeEMS there.
Thus, from this place I would like to ask for your support.
For their part, I offer designing new hardware for your project, and testing its functionality, developing FreeEMS.
If this project succeeds, it could be a great advertising around FreeEMS.
Ultimately I would expect from ECU (sometime?):
-V6/V8 turbocharged engine control
-operating turbo's solenoid valves
-knock-sensor support
-fuel consumption display
-good solution to idle maintaining (I'm not sure if MAP is enough)
-self-learning based on the signal from WBO2 probe
I hereby would like to ask you to refer me to the key topics / posts that I should read to get familiar with building own FreeEMS.
Maserati Biturbo project
malcom2073
Re: Maserati Biturbo project
Hello, and welcome!!
First thing would probably be the current status of FreeEMS: viewtopic.php?f=41&t=1699
This should give you a top level idea of where the project is at in terms of maturity.
The currently supported configurations: viewtopic.php?f=54&t=1084
I'll post more with later, or hopefully someone else will chime in.
For now, thank you, but I'm waiting for further information.
