My ECU build thread for Citroen ZX 1.6 gasoline
For people running FreeEMS to discuss it and ask any questions about using and adjusting it.
HotCat
Post by HotCat »
EMStudio is nice and easy to use, I use it to debug my A/D circuite and the MAP works fine and so is my MAX9924. My question is how to stimulate injectors
my MAP
under normal ambient temperature
Drain it and see how low it can reach
This is the pressure my Buick Regal's GM 3.1 can reach at idle
Use a function generator to stimulate tach input
I can see the count increase again and again from 0-255
Then I populate vnp10n07, but the leds don't blink but keep light on
I use this firmware so far
any way, can I use 60-2 decoder to run my engine?
Re: My recent work and some questions
Re your FETs, load them with a simple light bulb to ensure the outputs go to the 12V rail when off.
Re testing your FETs, you can use the BencTest firmware to switch them on and off. MTX still supports it AFAIK, but may crash. You can get SOME results from the prerolled bin packets in the lib dir without any tool, too.
Re 60-2, maybe. It needs work, and testing. You can certainly try, but if you do, do NOT rev above 2500. If you get it running and take 17th place with the low redline I'll prioritise the fix for that.
PS, good to see you around again! :-)
malcom2073
Post by malcom2073 »
HotCat wrote:EMStudio is nice and easy to use, I use it to debug my A/D circuite and the MAP works fine and so is my MAX9924.
Yay! :)
Give him bench test mode ;-)
HotCat
Post by HotCat »
Fred wrote:Re your FETs, load them with a simple light bulb to ensure the outputs go to the 12V rail when off..
Good idea, I'll try it
Fred wrote:Re testing your FETs, you can use the BencTest firmware to switch them on and off. MTX still supports it AFAIK, but may crash. You can get SOME results from the prerolled bin packets in the lib dir without any tool, too.
I don't like MTX, I prefer EMStudio. Or I can simply skip this step, load 60-2 firmware and use a 60-2 sin wave to stimulate it, is that feasible?
Fred wrote:Re 60-2, maybe. It needs work, and testing. You can certainly try, but if you do, do NOT rev above 2500. If you get it running and take 17th place with the low redline I'll prioritise the fix for that.?
I decide to do a parallel install, fuel only. A lot of work need to be figures out myself such as how to generate IAT and CHT curve for my OEM sensor. Does FreeTherm have windows binary like EMStudio. Also I would like to use my timing light to calibrate the ignition offset in 60-2
Fred wrote: PS, good to see you around again! :-)
I've read your milestone, I know how to participate my role, I have enough patient, I am your tester not simply a user
MTX is good for what it is, and that's a MS app. EMStudio is good because it's a custom fit around our needs. IE, Mike listened to me :-)
Yes, if you can generate the pattern, it should work at low RPM at least.
The limitations apply to all uses, even just sensing RPM with no injection or ignition.
Neither of these are critical for getting up and running. Both only matter in terms of tune "portability" and can be semi ignored at first provided that they're closish.
FreeTherm ONLY exists as a .exe :-) It's a mono C# app. The latest one works on Linux again, not just windows like the older ones (maintenance decision by mono maintainers).
Necessary step on any vehicle setup.
Fred wrote:PS, good to see you around again! :-)
I wasn't complaining at all! Just saying that you've not been around for a while, and your presence has been missed! <3 :-)
HotCat
Post by HotCat »
I can see the rev above 2500, what's happend? very confused
I don't understand the words "provide that they're closish", can I completely ignore the IAT and CHT, only have Tach, MAP to start the engine?
I wasn't think that way, I just want to express I always to be the FreeEMS follower
My 60-2 interface seems OK, it's time to figure out how to configure firmware to accept my new engine
What is the combustion Sync flag mean?
HotCat wrote:I can see the rev above 2500, what's happend? very confused
That doesn't mean that it's safe or working correctly, though! Beware!
You can't leave the inputs floating/badly wrong, unless you hard code it in the config. Which is easy to do. HOWEVER, CHT will need a potentiometer so you can track engine temperature to control enrichment. Cold setting won't work when hot and vice versa. Cold enrich is a big value for most engines.
So, on that basis:
CHT: Get it working within 5 degrees of reality or so before you try to run it.
IAT: Put a resistor in its place, or set the config to fixed value or approximate weather conditions where you're at. Or hang a spare sensor off the front bumper and wire that up.
I appreciate it! I hope it continues into the future.
If you have any questions, please ask. :-) Andy, Sim, Peter, Sean, Mike, and likely others all know how to do it :-)
Unused in your installation, so ignore it. Ditto cam sync.
HotCat
Post by HotCat »
I know how to do it in firmware now
By 3 years evolution, FreeEMS source code had significant changed from 0.0.1. The comments are rich and easy to understand. I can see Fred put so much effort to encapsulate the basic data structures in order to keep the code clean and high level abstract, I hardly find a hardwired code around, I think Fred definitely want FreeEMS to be run on all the gas engines every build. I start to believe FreeEMS don't need document, the source code is the best document. By searching the CONFIG == PRESTO_ID, I quickly sorted out how to make FreeEMS to schedule my injectors and ignition pins. Also I can construct my own VE table based on Fred's truck. Other parameters that I don't understand can always get the answer reading the source code
#elif CONFIG == CATPOWER_ID // HotCat's Citroen ZX
		anglesOfTDC: {ANGLE(0), ANGLE(180), ANGLE(360), ANGLE(540), ANGLE(0), ANGLE(180), ANGLE(360), ANGLE(540)},
		outputEventPinNumbers:       {0,1,0,1,2,3,2,3}, // Wasted spark, semi-sequential TODO migrate this to sequential
		schedulingConfigurationBits: {0,0,0,0,1,1,1,1}, // First four ignition, last four injection
		decoderEngineOffset:      ANGLE(144.00), // need to prove with timing light
		numberOfConfiguredOutputEvents:              8, // See two lines above
		numberOfInjectionsPerEngineCycle:            2  // Semi-sequential, for now.
ADC reading, generateCoreVars, generateDerivedVars, calculateFuelAndIgnition, scheduleOutputs, this is how the FreeEMS works
At last, Merry Christmas
HotCat wrote:By 3 years evolution, FreeEMS source code had significant changed from 0.0.1. The comments are rich and easy to understand. I can see Fred put so much effort to encapsulate the basic data structures in order to keep the code clean and high level abstract, I hardly find a hardwired code around, I think Fred definitely want FreeEMS to be run on all the gas engines every build. I start to believe FreeEMS don't need document, the source code is the best document.
Thank you very much for the very kind words! ♥
Great, but there are some "gotchas" there. Please make sure you're rebased onto the latest and then push a clean change set to github for review before you try to fire it up.
Structure/format, OK, fine. But the values in the table are mostly wrong - even for my truck :-)
This looks correct :-) I'd recommend putting the angle at either 0 or 180 as a base, though. Make the math simpler when it comes time to sort out the real number.
For now! I really dislike the way it's done, so it'll be changing a lot in future. It'll stay similar in some ways, though :-)
M$ Visual Studio, well I'll be damned, I never thought I'd see the day! :-o
To you too, hotcat! :-)
