View unanswered posts | View active topics It is currently Sat Mar 23, 2019 5:10 am
Reply to topic  [ 5 posts ]
1987 Camaro 383 configuration questiosn
Alright, so I finally got my Jaguar A3 installed and wired in... so now I need help getting it configured.
This is how the ECU is wired:
https://plus.google.com/photos/11223366 ... 8139945074
I know, it's a bit silly, but bear with me. The injector side is stock wiring. They're wired together into two groups, and there's nothing I can do about that right now. Each mosfet is capable of driving 6 injectors at once, so no matter which MCU output gets fired, it'll never overheat (Go Jaguar!)
My current config can be seen in hash c5e359cf06e0c063c0aa117c641a22325f653bf1 of my fork of the firmware: https://github.com/malcom2073/freeems-vanilla
That includes my decoder, which was written by Sean K, surprisingly quickly.
The car holds sync, however it just refuses to start, and smells horribly like too much fuel. Logically, my config must be wrong.
I've tried a couple different configs,
My initial config, this one was supposed to fire the injectors fairly often, but due to having issues I attempted to simplify it, see the config below.
Code:
anglesOfTDC: {ANGLE(0), ANGLE(90), ANGLE(180), ANGLE(270), ANGLE(360), ANGLE(450), ANGLE(540), ANGLE(630),ANGLE(0),ANGLE(180),ANGLE(360),ANGLE(540)},
outputEventPinNumbers:       {0,0,0,0,0,0,0,0,2,4,3,5}, // LTCC e-dizzy, semi-sequential injection 1/6, 8/5, 4/7, 3/2, and repeat
schedulingConfigurationBits: {0,0,0,0,0,0,0,0,1,1,1,1}, // See below two lines
decoderEngineOffset:               ANGLE(8.00), // Dist is at 0 degrees.
numberOfConfiguredOutputEvents:             12, // First half ignition, second half numberOfInjectionsPerEngineCycle:            2  // Full sync semi-sequential
This is the one I would prefer to run. The purpose of this one was to imitate the stock system. Fire each of the two banks, one per crank rotation. However apparently that's not quite how it works....
Code:
anglesOfTDC: {ANGLE(0), ANGLE(90), ANGLE(180), ANGLE(270), ANGLE(360), ANGLE(450), ANGLE(540), ANGLE(630),ANGLE(0),ANGLE(360)},
outputEventPinNumbers:       {0,0,0,0,0,0,0,0,2,4}, // LTCC e-dizzy, semi-sequential injection 1/6, 8/5, 4/7, 3/2, and repeat
schedulingConfigurationBits: {0,0,0,0,0,0,0,0,1,1}, // See below two lines
numberOfConfiguredOutputEvents:             10, // First half ignition, second half injection
numberOfInjectionsPerEngineCycle:            1  // Full sync semi-sequential
So here I am, asking for some advice. I can post up some logs of it cranking over and almost starting if necessary... but I'd like some insight into exactly what the config does, how it does it, and how it should be set up for my wiring setup. Any help would be appreciated, thanks!
EMStudio
Interesting Stuff
My Car
Sat Oct 27, 2012 1:48 am
Some clarification.
My distributor is set to 8degrees advanced from TDC, and freeems is not yet controlling timing, so timing does not change ever.
When I say does not start, it cranks over, sputters a few times, and dies. Not much though, if I keep the starter engauged it doesn't grind, just cranks, one or two sputters, then goes back to cranking.
Edit: More clarification per hentaixp:
33lb/hr injectors (338cc/min?)
Cranking RPM: 130-200rpm
BasePW: 9-10ms
ActualPW: 24ms (ish)
Another edit:
datalog of a couple of crank events:
http://mikesshop.net/EMStudio/logs/logs.tar.gz
Yet another:
http://www.youtube.com/watch?v=xt69Pb4EqmM&feature=plcp
^^ That's the best example of what it's doing.
EMStudio
Interesting Stuff
My Car
Sat Oct 27, 2012 2:00 am
Fix your f***ing FET situation, that's an image of anonymous internet fame right there! It'll be going up in daily WTF as soon as I'm done here. You made my morning. :-)
Once it starts it'll be lazy.
Sounds like you're flooding it. What about idle airflow? Got any? Using your foot on the pedal to get some?
At which duty? Code requires @ 100% many web figures are @ 85% or similar. Eg my RX7 "550s" are 650ish. Increasing this (to be more accurate) will reduce fueling.
Quote:
BasePW: 9-10ms
Fuel time per cylinder-cycle, without warmup, without dead time. I presume your engine is cold and your dead time is wrong.
No such variable.
Code:
fred@cheetah:~/workspaces/eclipse/freeems-vanilla/src$ grep -rn ActualPW . |wc
      0       0       0
The two configs posted above, with your fucked wiring, are equivalent (equivalently MS style/shit) in fueling IF, and ONLY IF, your dead time configuration is correct.
I've not looked at your config, or Sean's since 2 days ago when they made me cry.
I'll help you again after your injectors are being driven reasonably. By that I mean TWO, and ONLY TWO, CPU pins driving 1 (or 2 if you want) FETs, wired to 4 injectors per CPU output.
Sat Oct 27, 2012 1:31 pm
Oh, and do you get some vacuum or not? I didn't look at the log, but if your map sensor is lying to you, you're SOL.
Sat Oct 27, 2012 1:33 pm
Fixed. Pin 2 driving 4, pin 4 driving the other 4. I just had to clip the wires going to the other FETs heh
k
Using foot on pedal lets it start occasionally, but sounds like it's running on 1-2 cylinders, and dies VERY quickly and easily. I'm afraid to rev it up past 1500 like that.
100%
Yes, and probably.
Fred wrote:
No such variable.
Sorry, measured, not read.
Then help me fix mine. I'm going by what Andy and Sean tell me. By all means interject and help me fix it :)
Done.
Yes. Engine off is 98KPA, and engine cranking is around 80ish?
EMStudio
Interesting Stuff
My Car
Sat Oct 27, 2012 1:44 pm
