Page 1 of 3
Bootloader won't work on my board(It's working now)
Posted: Thu Aug 09, 2012 6:14 pm
by HotCat
My SCI function good and I can receive bytes from my test firmware
so I download the bootloader
and watch it run through BDM until it enters the dead loop
but the bootloader won't respond to the FreeEMS loader, the FreeEMS loader issues 0xb4, 0x0d
Find many issues on layout, some large current path doesn't have enough clearance to ground
I really regret to spend much time on HW, I should buy TechArt board
Re: Bootloader won't work on my board
Posted: Thu Aug 09, 2012 10:26 pm
2 things:
1) What type of serial do you have?
2) What state is your boot load jumper in?
If you have the right type of serial, and forgot the jumper, it'd be trying to run firmware code, and failing. You need to jumper it to make the serial monitor run and not bypass to the firmware. If the firmware is not installed, then you'll get nothing in that mode. If it's installed correctly it'll dump out data.
Make sure parity is off in the loader, which is the default, but in case you changed it...
Re hardware dev, keep at it, you'll get there in the end, and you can recycle the cpus and other ICs if you're careful.
Posted: Thu Aug 09, 2012 10:27 pm
I see the jumper in the picture. Check the voltage at it, please.
Posted: Thu Aug 09, 2012 10:32 pm
Re your SCI being good or bad, please record a data stream and try to decode it with the util in the firmware bin dir or OLV.
You can try this if you want:
http://tmp.fredcooke.com/OpenLogViewer- ... APSHOT.jar
Use a terminal: java -jar OpenLogViewer-0.0.3-SNAPSHOT.jar
Watch the text output from the app in the terminal. Paste the stats here in a code block.
Posted: Thu Aug 09, 2012 10:44 pm
by SleepyKeys
Hi,
Try this, to be sure that the serial monitor is at least trying to run.
With a terminal program, such as cutecom, send the following byte:
const char SMReturn = 0x0D;
and expect it to echo this:
const char SMRDY[3] = { 0xe0, 0x00, 0x3e };
-Sean
PS.
Setup the port like this:
115200, 8, 1, NONE
Posted: Thu Aug 09, 2012 11:24 pm
by DeuceEFI
HotCat,
Didn't you change one of pins on the BDM to prevent you from connecting the power reversed, or did you change the pin out of the BDM back to the universal standard?
It should have failed to connect to the MCU with the Freescale software if one of the four pins on the BDM was missing...
I'm just throwing out ideas...
Posted: Fri Aug 10, 2012 12:23 am
Deuce, that's a 10 pin cable, the 6 pins appear to be present on the board.
Hotcat, did you get a successful BDM burn of the serial monitor to the MCU and verify it by pulling it back off again? If not, that's the first step that you need to achieve before you try to use the loader.
Posted: Fri Aug 10, 2012 1:12 am
by HotCat
Fred wrote:I see the jumper in the picture. Check the voltage at it, please.
I've checked the voltage, when the jumper was on, I got 0.0v on net N-000106. When removing the jumper, I got 4.95v
Posted: Fri Aug 10, 2012 1:19 am
by HotCat
Sean0 wrote:Hi,
-Sean
PS.
115200, 8, 1, NONE
The FreeEMS_Loader already issues that 0x0D, but no respond
Posted: Fri Aug 10, 2012 1:26 am
by HotCat
Fred wrote:Deuce, that's a 10 pin cable, the 6 pins appear to be present on the board.
I wrote a tiny program in codewarrior, it can send string to my PC. So I think the BDM works fine. I burn the bootloader by loading the S19 file directly. It seems fine and no error messages. How can I prove it is OK? I am not understand your words "verify it by pulling it back off again?"
