Hello Users!
This thread will be a single sticky post containing the current recommended git hashes, repos and statuses.
Note: Hashes later than those mentioned are untested by the team and could destroy your engine or make your computer catch on fire. You've been warned.
FreeEMS Vanilla Firmware
Last updated/confirmed: Sun Mar 11 16:25:01 CET 2012
Last updated:
git://github.com/FreeEMS/freeems-vanilla.gitUse the dev branch on the bench for tests. You'll have to move to it on purpose as it contains untested code that is believed to be reasonable, but could be dangerous.
Current recommended hash: c76a4e0b5ed80c544456fa83992118fbf1b01b07
Latest publicly available hash: same as recommended or newer and untested
Tested by/on:
- Fred on the bench with lacerated in missing tooth and even teeth decoders
git://github.com/djandruczyk/MegaTunix.git
git://github.com/FreeEMS/MegaTunix.gitUse the djandruczyk repo master branch for testing. This is the default if you clone from djandruczyk and contains fresh code that could be unstable.
Current recommended hash: 6302de8f0f5308e4fa1b6f319cedf0b6d6e32242
Latest publicly available hash: 4c46e9e820674dcdccd4f9636abde296eda6bae8 segfaults on successful connect
Tested by/on:
- Fred on Debian with latest firmware (recommended hash)
- ToxicGumbo, DeuceEFI and prelude on Ubuntu with latest firmware (latest hash)
git://github.com/FreeEMS/OpenLogViewer.git
git://github.com/BenFenner/OpenLogViewer.git
git://github.com/fredcooke/OpenLogViewer.gitUse the BenFenner repo master branch for testing. This is the default if you clone from BenFenner and contains fresh code that could be unstable.
Use the fredcooke repo master branch for testing. This is the default if you clone from fredcooke and contains fresh code that could be unstable.
Current recommended hash: b13084784e9137e23e1df17b185a3df622986afd
Tested by/on:
- Fred on Debian and Mac OS-X 10.6 with latest firmware
git://github.com/seank/freeems-loader.git
git://github.com/FreeEMS/freeems-loader.gitUse the seank repo master branch for testing. This is the default if you clone from seank and contains fresh code that could be unstable.
Current recommended hash: d428e265e46b956ab34e0f51ece531d550d7a35c - Dumps ugly debug to console, but works OK.
Tested by/on:
- Fred and Sean on Debian
For other packages and for un-endorsed versions, visit the network graph page of the github repo and select the latest from someone who you trust.
https://github.com/FreeEMS/freeems-vanilla/network
https://github.com/FreeEMS/OpenLogViewer/network
https://github.com/FreeEMS/MegaTunix/network
https://github.com/FreeEMS/freeems-loader/network
https://github.com/fredcooke/FreeTherm/network
https://github.com/johnhowe/Lacerated-P ... ae/network
