View unanswered posts | View active topics It is currently Sat Mar 23, 2019 5:29 am
Reply to topic  [ 7 posts ]
User Configurations and Equipment
Users unite! Post configuration information about your hardware, software, and diagnostics equipment here so that we can better work together on troublesome issues and installs. This will also give us a bird's eye view of who's using which builds, what hardware, and who has the potential to test specific scenarios. For the purposes of this thread, update your information as often as if changes!
Obtaining build version information:
  1. If you're using debs/exe installers, specify the filename.
  2. If you've obtained a project with a release cycle through Git, enter your cloned or checked out copy's top level directory and type 'git describe' or 'git log | head -1'.
  3. If you're using a project that doesn't have any obvious release information, note the date you obtained a copy and when it was compiled.
Only use this thread to post configuration information.
Discussion should go here: viewtopic.php?f=54&t=1638.
Post Template: (Please copy/use this)
Code:
[u][b]Computer 1:[/b][/u]
[list]
  [*][b]OS/Rel:[/b]
  [*][b]Arch:[/b]
  [*][b]Toolchain:[/b]
  [*][b]FreeEMS-Loader:[/b]
  [*][b]MegaTunix:[/b]
  [*][b]OpenLogViewer:[/b]
[/list]
[u][b]Hardware:[/b][/u]
[list]
  [*][b]Board(s):[/b]
    [list]
      [*] <board #1 here> running <firmware hash>
      [*] <board #2 here> running <firmware hash>
    [/list]
  [*][b]USB-to-Serial adapter(s):[/b]
    [list]
    [/list]
[/list]
[u][b]Dev Equipment:[/b][/u]
[list]
[/list]
[u][b]Real Engines:[/b][/u]
[list]
[/list]
Edit: 17 March Fred removed draft status and added git log advice
Fri Mar 09, 2012 7:10 am
Computer 1:
  • OS/Rel: Kubuntu 10.04
  • Arch: AMD64
  • Toolchain: Latest
  • FreeEMS-Loader: Latest
  • MegaTunix: 4f97471
  • FreeEMS Studio: Latest
  • OpenLogViewer: cde2c4d w/ Maven 3.0.4
Computer 2:
  • OS/Rel: Windows 7
  • Arch: AMD64
Computer 3:
  • OS/Rel: Mac OS X 10.7.5 w/ Xcode 4.3.3
  • Arch: 3.4GHz i7
  • Toolchain: Latest
  • FreeEMS-Tuner: r20091105152800
  • MegaTunix: 7fe51d7
  • EMStudio: a835282
  • OpenLogViewer: c43d3f8 w/ Maven 3.0.4
Hardware:
  • Board(s):
    • TA Adapt9S12XDP512M2 Rev20 (unmodified) running cb698b5
    • MegaSquirt 2 (for testing MTX features)
  • USB-to-Serial adapter(s):
    • KeySpan ZT3241E
    • Dynex PL2303
Dev Equipment:
  • Rigol DS 1052E oscilloscope
  • Fluke 87V multimeter
  • Open Workbench Logic Sniffer (32 channels)
  • Aoyue 968 soldering station
  • PCB etching materials
  • Schmartboards: (6x) 202-0031-01
Real Engines:
  • 2004 Toyota 2.4L 2RZ-FE (Build page)
  • 2008 GM 2.4L EcoTec
Fri Mar 09, 2012 7:13 am
Computer 1: roadeee
  • OS/Rel: Debian unstable + patch upgrades (dual boot with Windows 7 Starter, not booted for months/years)
  • Arch: Atom 280 single core 1.6
  • Toolchain: Release from tools site
  • FreeEMS-Loader: No idea
  • MegaTunix: No idea
  • OpenLogViewer: No idea
Computer 2: freeair
  • OS/Rel: OS X 10.6
  • Arch: Core2duo 2.19gHz
  • Toolchain: Assorted, from source, not used to build for real hardware, only to compile
  • OpenLogViewer: Latest
Computer 3: cheetah
  • OS/Rel: Debian unstable + patch upgrades (Dual boot with OSX 10.6, not booted since Debian install)
  • Arch: Core2duo 2.4gHz
  • MegaTunix: Latest
Computer 4: rwdlsd
  • Arch: Atom 330 dual core 1.6
  • Toolchain: Ancient
  • FreeEMS-Loader: Ancient if at all
  • MegaTunix: Ancient if at all
  • OpenLogViewer: Ancient if at all
Computer 5: raptor
  • OS/Rel: Top secret
  • Arch: 32 bit VM
  • FreeEMS-Loader: N/A
  • MegaTunix: N/A
  • OpenLogViewer: N/A
Computer 6: wifeee
  • OS/Rel: Windows 7 starter (Spanish/Español)
  • Arch: Atom no idea
  • Toolchain: Relase from tools site
  • FreeEMS-Loader: One off win build from months ago
  • MegaTunix: One off win build from months ago
  • OpenLogViewer: One off jar from months ago
Computer 7: XP VM
  • OS/Rel: Windows XP
  • Arch: 32 bit VM
  • Toolchain: No idea
Computer 8: Debian VM
  • OS/Rel: Debian not sure which ?
  • Arch: 32 bit VM
Computer 9: Ucuntu VM
  • OS/Rel: Ucuntu 12.04 pre-release updated 9th March 2012
  • Arch: 32 bit VM
  • Toolchain: CodeWorrier (spop)
  • MegaTunix: No
  • OpenLogViewer: No
Computer 10: Wifeworks
  • OS/Rel: Windows Vista (Spanish/Español)
  • Arch: No idea
  • Toolchain: No
  • MegaTunix: No
  • OpenLogViewer: No
Hardware:
  • Board(s):
    • TA running ?
    • PumaS1 running ?
    • FTDI (in Puma)
    • FTDI (RS232 Adapter)
    • PL2303
    • HW RS232 in rwdlsd
    • DSE cheapy
    • Other cheapy
Dev Equipment:
  • DSO Quad (2 probes, 2 clips)
  • Saleae (8 clips)
  • OpenBench LogicSniffer (32 clips)
  • FredStim
  • JimStim, broken
  • Original bench rig
  • 2x SLC_OEM eval
  • 5x TPIC8101 chips
  • 2x CAN chips
  • 2x Freescale USB2SER chips
  • 2x TI USB3401? chips
  • Assorted S12X chips
  • Assorted hand tools
  • Vellemen tstat soldering station
  • Rommelsbacher-Cooke reflow oven
  • TA USBDM
Real Engines:
  • None :-(
Sat Mar 10, 2012 1:58 am
Computer 1: DeuceEFI
  • OS/Rel:Debian 6.0.4 32-bit "squeeze"
  • Arch:Intel Atom Single-Core/1.5Gb RAM
  • Toolchain:Release from tools site (32-bit)
  • MegaTunix:megatunix 0.9.24-SNAPSHOT_6e2744
  • OpenLogViewer:Not yet installed
  • KiCAD:2010-03-14
R.I.P.Computer 2: DeuceEFI_desk
  • Arch:AMD Athlon II X2 220 Dual-Core/ 3Gb RAM
  • KiCAD:2010-03-14
Computer 3: Andy-LT
  • OS/Rel:Windows 7 64-bit
  • Arch:Intel Pentium Dual-Core T4500/ 3Gb RAM
  • Firmware:No
  • Toolchain:No
  • MegaTunix:No
  • OpenLogViewer:No
  • KiCAD:2011-07-08 BZR 3044
  • Codewarrior:Version 6.1 Build 10221 (only for HiWave.exe debugger to flash with TBDML)
Computer 4: FreeEMS-Tuner
  • OS/Rel:Lubuntu 12.04 32-bit
  • Arch:Intel Dual-Core/4Gb RAM
  • EMStudio:an older version and a newer dev version, will post hashes later
  • OpenLogViewer:very old version for FreeEMS LA and a newer release, will post hashes later
  • KiCAD:2010-03-14
Hardware:
  • Boards:
    • DIY TA style 112pin MCU prototype on a SchmartBoard, serial comms only
    • TA board with all recommended modifications
    • Jaguar A2 prototype, only for MCU and USB comms testing
    • Jaguar A3 prototype, Serial #1
    • MS2
    • USB to Serial: Prolific Technology, Inc. PL2303 Serial Port adapter
    • USB-to-Serial adapter: FTDI (on Jaguar boards)
Dev Equipment:
  • Assorted DMMs (I never go anywhere without one)
  • Saleae (8 channel Logic)
  • OpenBench Logic Sniffer with Buffer Wing (32 channels)
  • DSO Quad
  • JimStim
  • Additional S12X 112-pin MCUs
  • Additional S12X 144-pin MCUs
  • Assortment of hand tools
  • Weller soldering station
  • DIY Reflow Soldering Oven (Black & Decker 1200W with custom controller)
  • DIY TBDML
Real Engines:
  • 1989 GM 2.8L V6 with DIS
  • 1989 GM 3.8L V6 with DIS
  • 1996 GM 2.2L I4 with DIS - FreeEMS conversion in progress 11/6/2012
  • 1996 GM 3100 V6 with DIS - FreeEMS engine #11 :-)
  • 1997 Ford 3.8L V6 with EDIS
  • 2005 Toyota Matrix 1.8L I4 with COP (future RAVAGE engine)
EDIT: on 4/7/2012 to update Development Equipment.
EDIT: on 11/6/2012 to add DSO Quad and update computers
http://www.coolefi.com
Sat Mar 10, 2012 3:33 am
Computer 1: AKA preludelinux
  • OS/Rel: Ubuntu 10.04 LTS
  • Arch: core2quad 8GB Ram 2.4ghz
  • Toolchain: Outdated 64bit debs version ???
Computer 2: AKA preludelinux_lap
  • Arch: core2duo 4GB Ram laptop 2.2 ghz
  • Toolchain: built my own 64bit from source
Computer 3: AKA preludelinux_dev
  • Arch: AMD64x2 4200 4GB Ram garage pc
  • Toolchain: OLD outdated .debs 64bit version ???
Computer 4: AKA preludelinux_tv
  • Arch: AMD64x4 3.8ghz 8GB Ram tv pc
Common Development Environment
Hardware:
  • Board(s):
    • TA Card #1 - Most Current Firmware
    • DIY TA Card#2-11! - Nothing yet i have to build them and Document them!
  • USB-to-Serial adapter and extra boards(s):
    • pl2303 usb > serial x2
    • jimstim
    • MS2
Dev Equipment:
  • 2x scopes
  • Many Multimeter
  • Auyou Soldering Workstation
  • boxes and boxes of electronic parts
  • plain soldering and de-soldering gun / solder sucker , misc tools
  • plans to get more!
  • LA 32 port from seed studio
Engines / Cars
  • 1987 325 BMW E30
  • m52b28 NA engine FreeEMS will run it soon!
  • plans to get more cars and engines!
Sat Mar 10, 2012 7:51 am
Earth
  • OS/Rel: Windows 7 64-bit
  • OS/Rel: Mac OS X Lion
  • OS/Rel: Ubuntu 10.04 LTS 64-bit
  • Arch: Intel i7 2600k
  • Toolchain:
  • FreeEMS-Loader:
  • MegaTunix:
  • OpenLogViewer:
SnowWhite
  • OS/Rel: OS X Lion
  • Arch: Core 2 Duo T7200
  • Toolchain:
  • FreeEMS-Loader:
  • MegaTunix:
  • OpenLogViewer:
Hardware:
  • Board(s):
    • Arduino piggyback
    • Assorted FTDI FT232R
Dev Equipment:
  • Fluke 73 DMM
  • Et al.
Real Engines:
  • Jaguar 5.3L HE V12 Engine w/ GM TH400 for 1972 XJ12 conversion project (first up)
  • (Reference) Jaguar 5.3L HE V12 with Lucas Digital-P in 1982 Daimler Double-Six (UK-Spec/Emissions)
  • (Reference) Jaguar 5.3L HE V12 with Lucas Digital-P in 1985 Jaguar Sovereign HE (US-amended Euro emissions)
  • (Reference) Jaguar 5.3L V12 with Bosch D-Jetronic in 1977 Jaguar XJ12L
  • Assorted Jaguar XK I6 Engines in pieces, with Stromberg carbs
  • Jaguar 4.2L XK I6 Engine (damaged) with Strombergs in 1976 Jaguar XJ6L 4.2L
  • Jaguar 4.2L XK I6 Engine (damaged) with Bosch L-Jetronic in 1979 Jaguar XJ6L
  • 4.0L AMC I6 in 1987 Jeep Wagoneer
  • VW I4 2.0T in 2008 VW Jetta Wolfsburg Edition 2.0T
Tue Apr 03, 2012 4:50 am
Computer 1:
  • OS/Rel: Kubuntu 12.04
  • Arch: x64\
  • Toolchain: None
  • FreeEMS-Loader: 0.1.0-SNAPSHOT-282-ge5def3a
  • MegaTunix: 0.9.24-SNAPSHOT-1187-gb6a737b
  • OpenLogViewer: 0.0.3-SNAPSHOT-119-g1a476d2
  • EMStudio: Newer than in git
Hardware:
  • Board(s):
    • TA Card, running random bench test firmwares
    • Jaguar Serial #3, running latest Listener firmware
    • Unassembled Jaguar from Kennybug. Not running or even assembled
Dev Equipment:
  • HP 54501A 68ch Logic Analyzer
  • HP 1662A 100MHz Digitizing Oscilloscope
  • Fluke TrueRMS Multimeter
  • Weller 50W adjustable temp soldering iron
  • JimStim
  • Tons of assorted Arduinos, relay boards, random assorted components
  • Assorted ARM dev boards, Sheeva Plug, Beaglebone, etc
Real Engines:
  • 1987 Small Block Chevy 383
  • 2002 Mazda Protege LX, 2.0l
  • 2007 Yamaha VStar 650, carbureted
EMStudio
Interesting Stuff
My Car
Tue Oct 23, 2012 1:52 pm
