We have two running users right now. One is happy with bog standard code. The other wants a few things, and our next up and coming user wants a few things.
Simis wants:
- Tacho output
- Coolant ignition timing trim
- Air temp ignition timing trim
- Tacho output
- TPS based delta enrichment
I've promised Sim tacho code when he gets a circuit built and the other code when he shows me clean logs, he's been busy. I've promised Em_knaps TPS delta enrich when his engine runs and is smooth and tacho after that.
