When installing FreeEMS on your vehicle for the first time, it is important to follow the correct procedure!
This thread is a draft, please post in it (anyone, despite the forum description), offer feedback, and help develop it into something great.
- Static test - coils and injectors without power
- Dynamic test 1 - coils and injectors without power
- Dynamic test 2 - coils powered up, injectors without power
- Attempt to start - coils and injectors powered up
- Dynamic test 3 - coils and injectors powered up
Static test - coils and injectors without power- Verify that fuel pump comes on and goes off after a few seconds (LED should do the same)
- Verify that voltage readings look correct (config for your resistor divider network correct)
- Verify that IAT and CHT readings look correct (config for your sensors correct)
- Verify that TPS movement is reported (you can calibrate this at this time)
- Verify that MAP (and AAP) read normally (config for your sensors correct)
- Verify that all injector outputs are floating or high (LEDs should be off)
- Verify that all ignition outputs are in a state that causes the coils to not draw current (this depends upon your setup)
- Verify that you have clean error free communications between the box and the PC by taking logs and analysing the packets in a binary stream with a parsing tool.
Dynamic test 1 - coils and injectors without power- Optional: Load the listener decoder and take an LA log
- Crank the engine over and ensure that you get a clean RPM signal with no loss of sync (using the correct decoder)
- Observe the ignition LEDs flashing and make sure the number of outputs is configured correctly (injector LEDs on Puma Spin1 will not flash without injectors connected)
- Check that reported ignition timing, dwell and injector pulsewidths make sense for your setup (config for your engine hardware correct)
- Take a normal basic datalog and ensure that analog inputs (and RPM) are free of noise
Dynamic test 2 - coils powered up, injectors without power- Ensure that your coils are not charging with the key on and the engine at rest
- Verify and/or set the engine offset angle such that the reported timing in MTX matches what you see on a timing light (it is better to load a flat table for this check)
- During this early alpha phase of testing, it will pay to verify the timing of all of your coils, especially if unusual configurations like V twin are being used
Attempt to start - coils and injectors powered up- Ensure that your injectors are not flowing with the key on and engine at rest
- Ensure you are out of gear, and that everything is clear of rotating parts
- Crank the engine over and enjoy as it splutters into life! (if not, remove fuel (first) or add fuel (second) until it does)
Dynamic test 3 - coils and injectors powered upBegin logging before-hand such that post analysis can be done afterward.
- Re-verify the ignition timing on the now running engine
- If that can't be done, tune the VE map until it can free rev a bit and then recheck.
- Only tune enough to allow the engine to warm up, tuning while not warmed up will result in a bad tune.
- Fully warm the engine up and if a fresh build, check for leaks
- Once warmed up, tune the idle and low load regions by free revving it at various throttle openings
- Now go for a gentle drive and tune the cruise and light throttle regions more
- Tune the rest of your VE map using normal tuning techniques
You're done! Enjoy owning a FreeEMS powered car!
FreeEMS dev diary and
its comments thread and
my turbo truck!n00bs, do
