Req: PWM pin reassignment
Posted: Wed Apr 06, 2011 1:15 pm
I had a chat with Fred about PWM, and an interesting discovery was made concerning PWM pin assignments.
Right now, there are two drivers connected to ports PP0.1 and two signal outputs at PP6.7, while ports 2 through 5 are for stepper controller.
The request is to rearrange PWM output to pins 0 through 3, and so that drivers connects to P0 and P2. This allows flexibility in PWM configuration, allowing either two 16-bit drivers or two 8-bit drivers with two 8-bit signal outputs.
