Also, it produces a page without a title, if there is a config option to give it one, that'd probably be worthwhile if it's low hassle. If you can automate the naming to index.html that's a win too.
BTW, Jammi is keen to work with you to produce a web BOM with configurability built in and the howto doc pieces built in too, so you would select your config and be displayed a BOM and a customised howto guide for your specific config. Sounds cool if you're interested in working with him. I'd like to see that for RavAGE, so this would be good practice.
Preston's Element 14 BOM Attempt
Re: Preston's Element 14 BOM Attempt
Done, as much as possible I believe.Fred wrote:Done, if it doesn't look correct on your end please screen shot that and post. Thanks. - Checked - see below, it still looks bad.Fred wrote:
- See if you can make the inset part number links look correct in html
Done.Fred wrote:Done - Checked - Jumpers still need part numbers, other pages have that.Fred wrote:
- RPM page is missing: Two 1k resistors, two jumpers (were 1k resistors), two left out zeners (note not to buy or install).
Well that's it !!!
Yay!
Preston.
I have added a "Coming soon" to the final page. I will continue to work on this and add it in when I've got it working properly.Fred wrote:Also, it produces a page without a title, if there is a config option to give it one, that'd probably be worthwhile if it's low hassle. If you can automate the naming to index.html that's a win too.
Jammi's idea sounds great, I would defiantly be keen.
Preston
I gave you bad advice! The move to index.html is a fail. if you can export directly to just "index" such that there is "index.htm" and "index_files" then it will be ok, otherwise we have to leave it long and put an index pointing at the log version.
OK:
http://puma.freeems.org/preston.bom/ - fixed! :-)
Don't bother renaming it, leave it as is.
Looks wise:
One more correction, remove the http://stuff.fredcooke.com/spin1howto/spin1.html link, which I'm about to delete, and put the http://puma.freeems.org/how.to.guide/spin1/ link in it's place.
Part numbers confirmed to be added.
Looks wise:
- First page, 10k pull up mod "1 x" quantity overlaps the part number to the right.
- AAP page, "OEM AAP)" hangs out the right hand side outside the coloured bit.
- RPM page almost looks ok, half the B hangs out, and the 4 touches the M
Not the first time and wont be the last I'm sure! Not that I can talkFred wrote:I gave you bad advice!
I'll see what can do re cross platform text. The link change is a peice of cake, consider it done!
Preston.
Woop Woop!!
Last night a components order was placed to complete 5 Puma Boards !!!!! that's a soon to be 500% increase in puma testing pool.
The hard work is starting to pay off
Still to be completed are the following.
- Auto generation of the order tab
- Linking to appropriate Puma how to sections
250%, buit still awesome, I guess you can not count Marcos's one, as he only idled it for 5 mins at the top of a hill and since then it's been in service collecting dust :-)
lol, yep I only counted boards in the testing pool atm
Oh, in that case, it's an infinite improvement because mine is just collecting dust right now and will continue to do so for at least a few more weeks :-(
