Puma board MAP vs AAP circuit
slacker.cam
Re: Puma board MAP vs AAP circuit
Post by slacker.cam »
Cheers for the link to the Bosch datasheet. It makes sense now. Marco (if that's his name) has allowed for the use of either the MPX sensor or a Bosch sensor of some description.
I'm going to build mine as per the MPX datasheet (same as the AAP circuit).
Fred - you really should change my name on here to slacker.cam! I don't need to do much to get the motor ready to run, basically just throw the sump back on, bolt up the flywheel, attach a starter motor somehow and modify the extractors to fit. Couple of weekend days work at the most.
slacker.cam wrote:Cheers for the link to the Bosch datasheet. It makes sense now. Marco (if that's his name) has allowed for the use of either the MPX sensor or a Bosch sensor of some description.
Marcos, is his name :-)
slacker.cam wrote:Fred - you really should change my name on here to slacker.cam!
Done! :-p
Don't forget the loom!
