Fred, can you add to the spin1.html page (at the bottom under "Verifying correct operation of the firmware") what the proper Serial communications setting are? I know it is 115.2k baud, but what about data bits, stop bits, parity?
Thanks...
Spin 1 Documentation Ideas
Re: Spin 1 Documentation Ideas
I kind of feel like it's out of scope of the document? In fact, a lot of that stuff should probably not be there, with a reference instead to a document on testing any new setup. For the time being, consult the comms spec documents which lay out the serial settings in explicit detail :-)
For the record, though, 8,1,odd. I guess I could add it in in an abbreviated format like that.
Preston has been doing some work on the spin1 how-to, and I've given it a home on the puma site here:
http://puma.freeems.org/how.to.guide/spin1/
Currently many of the sections are duplicates, but he'll fix that soon.
Presto, if you add me to your repo as a contributor, i can do tweaks while you sleep and you can just "git pull" in the morning before you start. You can also just pull from the diyefi user repo where i push to, but...
I just had Jammi update the output to be in a subdir with all needed parts, so now it's simple to scp it up any time you tell me it's ready to roll :-)
Will do mate, if you tell me howFred wrote:Presto, if you add me to your repo as a contributor, i can do tweaks while you sleep and you can just "git pull" in the morning before you start. You can also just pull from the diyefi user repo where i push to, but...
Your help would be appreciated.I guess the sooner it is up to a decent state where others can try it with their build, then the sooner we get good feed back for spin2/Ravage.
Preston.
I'll try to get up early so we can work together in your evening to get that sorted out.
Preston has been doing some more work on the spin1 how-to, it's uploaded now, check it out here:
Expect this guide to be finalised in the next week or three :-)
It should make a nice xmas pressy for the Puma owners out there.
More changes overnight! Now split into separate pages, which is GREAT! Thanks Jammi for doing that and Preston for the content!
My feedback from IRC so that it doesn't get lost:
[09:21] <FreeAir> Lev8n: I'd split the pcb overview away from the bom stuff, and maybe even include it in the intro page to give that a bit of life
[09:22] <FreeAir> are "using the bom" and "bom config overview" really the same thing? right now i'd move config overview to the top and keep it on the same page, but maybe it's going to grow and move?
[09:22] <FreeAir> in general if there are two sections on a page, the shorter one will get lost if it's second
[09:23] <FreeAir> sourcing, surface mount, assembly tools should move to a new page too
[09:23] <FreeAir> i love the next, prev thing, perfectly appropriate for the content
[09:25] <FreeAir> general comment relevant before these changes, the images are auto scaled, i'd say make them smaller and make it more obvious that they should be clicked, or perhaps its obvious enough as is. Still, they take up too much space as is IMO.
[09:28] <FreeAir> Lev8n: I'd say that the polarised stuff should be marked obviously in bold caps whatever so it cant be missed, but all of the normal caps don't need to be marked. better to put something at the top saying "unless otherwise noted, resistors and capacitors can be installed in either direction, this excludes all tantalum caps, which will be clearly marked" or similar
[09:29] <FreeAir> will be a lot cleaner and easier to follow like that
[09:29] <FreeAir> ie, make noise when you need to and dont make as much noise when you dont
[09:36] <FreeAir> Lev8n: you're almost certainly onto this, but the spin 1 mods, this is a spin 1 guide, so rename to essential mods, also probably going to need to split the cutting traces and soldering jumpers to before/after relow, and thus on different pages,
[09:36] <FreeAir> and maybe assembly will end up on 3 pages as well. great work
These instructions are days away from being complete! Preston has done a STACK of work on them. Pretty soon I'll be personally emailing all puma owners and apologising for the delay on this. Great work Preston, you're a star! :-)
I too would like to commend Preston on his documentation and BOM efforts for PUMA! A job well done mate!
