STC имеет статус модератора! (STC now has the power!)
STC:
  • You can't delete posts, even I don't do that, much. You can ask me to move posts to the deleted section that is hidden, if you feel that it should be.
  • You can edit posts, but please, only do that if you really need to, and ALWAYS leave a message as to why, and a marker in the post such as "EDIT:" showing what you did. Usually useful for titles and dead links and spelling mistakes and so on. Don't adjust users comments unless there is a very good reason, and check with me first if you plan to do that, please.
  • You should be able to merge posts and split topics and other such actions, but be very careful with them, they're a bit awkward to use and can result in a mess easily. I'd recommend starting some threads in the english section and putting 5 posts in each, then playing with them, then getting me to delete them when you have a feel for it.
  • You can authorise posts by noobs, you can see a question mark on those posts/threads. There are none right now. This should be obvious.
  • Users should PM me if they think you're out of control, even if it's in Русский. I've had to deal with too many out-of-control moderators on other forums in the past, it sucks. Please let them know that they have a "court of appeal" with me.
  • Don't ever edit my posts without my permission :-)
  • You have permission to add a copy of this list below this in this post in Русский, in fact, I expect you to do it as your first moderator activity! Please :-)
  • You're the ONLY person other than me with these powers on this forum right now. Treat that privilege with the respect that it deserves! :-)
  • Let me know if you need any help or make any mistakes. If in doubt, take a backup of the material first by saving the thread(s) to your PC or something.
  • Above powers should only apply to the SECU-3 sections, including English, which I'll take care of too.
Русский:
  • Ты не можешь удалять сообщения, даже я это делаю редко. Ты можешь попросить меня, чтобы переместить сообщения в раздел удаленных, который скрыт, если ты чувствуешь что это нужно.
  • Ты можешь редактировать сообщения, но пожалуйста делай это только если тебе действительно нужно, и ВСЕГДА оставляй сообщение о причине и пометку в посте, например такую "EDIT:" показывающую, что ты сделал. Обычно полезно для заголовков, мертвых ссылок, орфографических ошибок и т.д. Не меняй комментарии пользователей, если на это нет веских причин, и согласовывай сначала со мной, если ты планируешь это сделать, пожалуйста.
  • Ты должен иметь возможность объединять посты, разделять темы и другие подобные действия, но будь очень осторожным с ними, работа с ними несколько неудобна и может легко привести к беспорядку. Я бы рекомендовал начать некоторые темы в англоязычном разделе и ввести по 5 сообщений в каждой и поэксперементировать с ними, а затем, когда у тебя появится уверенность, попросить меня удалить их.
  • Ты можешь утверждать сообщения от новичков, можешь видеть знак вопроса на этих сообщениях / темах. Пока этого нет, но очевидно это должно быть.
  • Пользователи должны PM-ить меня, если они думают, что ты вышел из-под контроля, они могут использовать даже русский в своих сообщениях для меня. Я имел дело со слишком большим кол-вом безконтрольных модераторов на других форумах в прошлом, это плохо. Пожалуйста, дай им знать, что у них есть "суд апелляционной инстанции" в моем лице.
  • Никогда не редактировать мое сообщение без моего разрешения :-)
  • Ты ЕДИНСТВЕННЫЙ человек, кроме меня, с такими полномочиями на этом форуме в данный момент. Отнесись к этой привилегии с уважением, которого она заслуживает! :-)
  • Дай мне знать, если тебе нужна помощь или ты сделал какие-либо ошибки. Если ты сомневаешься, прежде всего сделай резервную копию материала, сохранив тему на своем компьютере или что-то вроде этого.
  • Вышеперечисленные полномочия должны применяться только к разделам SECU-3, включая английский, за которым я тоже буду смотреть.
Re: STC имеет статус модератора! (STC now has the power!)
Если вы допустили ошибку (например создали более одного-двух одинаковых постов, хотите переместить тему и т.д.), то связывайтесь со мной (PM).
Если вы хотите удалить свой пост или тему, то пометьте его (например добавьте в качестве содержимого "delete me") и сообщите мне.
