Porting firmware to GCC
General English language SECU-3 discussions here. Обсуждение общих вопросов SECU-3 на английском.
Re: Porting firmware to GCC
I'll have to have a look at how you've done that! My make file deps are manual and prone to error, not cool. I need to improve that situation. Thanks for posting about it! :-)
I'm using -MD option for GCC. This option make it to generate separate dependency file (*.d) for each source file. Also you have to inclue list of mentioned dependency files to Makefile:
OBJECTS = $(SRC:%.c=$(OBJDIR)/%.o)
DEPS = $(OBJECTS:$(OBJDIR)/%.o=$(OBJDIR)/%.d)
all: ...
-include $(DEPS)
Thank you for ignore file, I've merged it to my master.
Thank you for that information! I'll try it next time I get near the keyboard! :-)
Are you loving git? It looks like I'm the ONLY person to have forked and pushed a commit!!! I thought people were contributing to your firmware? They must be doing it in some old fashioned and inefficient way. You should really do a translation of my git sticky (summarised) for your guys so that they can take advantage of it! It makes both their lifes and yours easier and better.
I just had a read up, I might do -MM -MF <file>.d for my setup as it is reasonable to assume that system components are fairly static. Thanks again! :-)
Yes, I am. And you are only person who have forked it :-) (unfortunately)
Did you mean that topic viewtopic.php?f=41&t=547 ?
That is a damn shame man! :-(
You could be pushy with them and tell them all future work HAS to come via git, or you don't want it. But that could backfire.
And yes, that is the thread. The colourful diagrams are the key points, and the narative that goes with them. Feel free to copy and insert cyrilic words there! :-)
I'll tell you what, I'll do a thread in your support and you can translate it for them to read.
EDIT: Done: viewtopic.php?f=52&t=1325
I also need the -MT option due to my multi stage compilation process.
m68hc11-gcc -MM -MF init.d -MT preprocessedc/init.pp.c init.c
And I need to automate that from the list of source files, however this is awesome! :-) Thanks.
Done and pushed, thank you so much for the inspiration, it is now 9 lines shorter and MUCH better :-)
Mine is a little fancier, you might want to check out the dependencies on headers by the dependency files part.
https://github.com/fredcooke/freeems-va ... 62720920a8
Inspiration is very important for open source projects :-)
On the last week I've improved source code of the firmware. Now it can be compiled using old versions of GCC, for instance AVR-GCC 3.4.6.
