Examples of missing tooth CAM VR device?
russian
Post by russian »
I want to get myself some toothed wheel + VR sensor assembly so that I can play without on a bench, without the rest of the engine. I guess that eliminates all the crankshaft wheels / sensors - I do not want the whole small block on the table :)
Maybe something integrated into the distributor, so that there would be a shaft I can spin by hand and a case? Has to be 80/90s or early 2000s so that I would find it in a junk yard.
Does any car match these criteria?
Re: Examples of missing tooth CAM VR device?
Toyota dizzy, but why VR, just use a square wave and bypass your signal conditioner...
russian
Post by russian »
Fred wrote:Toyota dizzy, but why VR, just use a square wave and bypass your signal conditioner...
Because I want to test my signal conditioner :)
Something like this 1994 Camry?
Do not see any missing tooth but that does not matter. Thank you for the fast response!
Yep, those are a good test of your circuitry. Why reinvent the wheel?
