My question tonight is: What's the best way to demonstrate the shortcomings of these circuits with an oscilloscope? i.e. Run the engine up against the rev limiter or switch to non resistor type spark plugs.
You weren't kidding about the fine pitch.Fred wrote:The max99xx chips are the best of the bunch, but very fine pitched, unless you grab a prebuilt board.
I think I need to invest in a bigger breadboard. I used 1k resistors for all of the resistors that didn't have values in the MAX datasheet.
