Admin wrote:I was going to suggest that blocking coolant flow was a bad plan, but your 6 stroke link answered that
Interesting stuff. I'm very much looking forward to seeing your progress.
Admin.
I don't want to rely on that, the coolant stays.
Admin.
DOH, that is the second time today I missed out a "negative" word like that...Wiglaf wrote:I am not blocking off oil and coolant to the head, I anticipate needing to cool and lubricate the coils.
Wiglaf wrote:it's a good concern. Other than the spring return as a fail safe for losing power, there isn't any other hardware fail-safe in my design. I'd have to think about what you said to try and add more but it sounds like an overcomplication.
I had originally planned on just having a table that would represent where the pistons are, so that no matter what the hell crazy stunt valve equations you came up with, the result would get clipped by the safety table. If the angle/tach input screwed up then.. i guess it would be like breaking a timing belt. It may not be quite as catastrophic though since a cam+rocker is mechanically solid, and here a piston would overpower a magnetic field.
