View unanswered posts | View active topics It is currently Thu Feb 20, 2020 5:38 am
Reply to topic  [ 30 posts ]  Go to page Previous  1, 2, 3
examples of bad code (and why) ?
Fred wrote:
throw an "unreachable code" error ;-)
I saw that, and for some reason I thought that you were commenting on misspelling or something. Then about 45 seconds later I got the joke. I think I've only actually seen that compiler error once.
:-p
Sat Jun 09, 2012 5:54 am
Having a slow day? :-)
Sat Jun 09, 2012 2:01 pm
I found this on the interwebs:
Code:
if (i<3 && b<0) {}
Bad variable naming, times two, plus magic number, times one, equals meaningless code.
Thu Oct 25, 2012 2:43 pm
Pointless code:
Code:
for (int i = 0; i < 1; i++) {
    // Lots of code, none of which referenced 'i'
Whose code is this, you ask? Mine! :-o
How the hell that made it near a source file I have NO idea. Possibly auto-generated or possibly a hang over from a loop with more than 1 in it?
It's gone now...
Mon Nov 05, 2012 5:02 pm
Not really bad code per se, but:
Code:
[WARNING] Messages.java:247: warning - @param argument "a" is not a parameter name.
[WARNING] Messages.java:247: warning - @param argument "the" is not a parameter name.
Tell me why I got these warnings? :-)
Tue Dec 11, 2012 10:10 am
z=x/++x
:-p
Fri Dec 21, 2012 8:03 pm
M$?
Fri Dec 21, 2012 9:55 pm
Code:
    try
      // Make one-line call
    } catch (Throwable e)
      throw new Exception(e);
Catching a throwable, sometimes, maybe, OK, rethrowing as a checked exception, what? :-/
Mon Mar 18, 2013 3:58 pm
I believe
Code:
a = a >> 1;
is bad code.
And some people do agree with me - http://stackoverflow.com/questions/2580 ... e-into-shi
There is the whole http://code-wtf.livejournal.com/ on this - I know it's a bit in Greek but most of it is code anyway :)
http://forum.diyefi.org/viewtopic.php?t=2070 http://www.rusefi.com
Mon Dec 30, 2013 3:16 am
Working on some horrendous code at the moment. Most of it is fairly average and normal, but a certain person did some stuff to it in the past that has rendered it nearly unusable now. The only example that I can succinctly post here is the following:
Removed 770,000 rows from a db table, none of which were used. This took over an hour to achieve. The database has no forreign key constraints. WTF. I can't explain more, really, but the 770 were autogenerated rows with no value... bleh.
Mon Dec 01, 2014 8:38 am
