This will be an ongoing thread...
To turn off usb auto mounting :
/etc/hal/fdi/policy/preferences.fdi
You can do it with a tool to avoid mistakes :
gconftool-2 --type bool --set /apps/nautilus/preferences/media_automount false
And a GUI way to do it in gnome :
http://ubuntuforums.org/showthread.php?t=13692
http://ubuntuforums.org/showthread.php?p=4823693
How to fix Ubuntu
How to fix Ubuntu
Re: How to fix Ubuntu
Add this to /etc/apt/sources.list :
## Medibuntu - Ubuntu 8.04 LTS "hardy heron"
## Please report any bug on https://bugs.launchpad.net/medibuntu/
deb http://packages.medibuntu.org/ hardy free non-free
#deb-src http://packages.medibuntu.org/ hardy free non-free
.... and install w32codecs, dvdcss thingy, acroread, skype etc
Why would you want to turn off automount USB?
What's the medibuntu do?
9/10 it really does just work TM, BUT, if you want to customise and configure shit, its a poor choice. Stuff is hard coded and broken for (normal and legitimate) uses other than those envisaged by the authors in London.
To recover data from a near dead disk. you want to type mount run a scrip and unmount. You don't want it mouting, reading the disk, showing a window with stuff in it, basically using up valuable and limited life in your near dead disk. first task after my fresh install - recover data from old disk... and i fcuking couldn't... without great difficulty.8InchesFlacid wrote:Why would you want to turn off automount USB?
Ah, ok, but for say..... walking up to a computer and using it.... then leaving automount on is a plus! It's good to know how to turn it off, but it doesn't make it worse for normal use to leave it alone.
thing is, version 7 "off" was a menu option in an advanced tab or similar...
version 804.... grrrrr, is an obscure command line option!!! with 2 ways to do it and a third to do it wrong.
now you see?
not possible to do it through the interface and a royal pain to do it via cmd line.
now you see?
I will certainly admit that ubuntu isn't a friendly front end so much as a gaurd yelling "KEEP DOWN OR VE VILL SHOOT" over linux that's just as hard to use as anyhing else
Thread moved.
I should probably point out that I gave up on this idea and went back to Debian again. Reasons were :
Inability to customise it to the extent that I wanted without great pain.
Great pain caused by :
Additionally I've started referring to it as poobuntu and screwbuntu to reflect my feelings about it :-)
- Broken dependencies pulling in things that the app didn't need and that I don't want.
- Broken packages with code modifications that make them fail to work when things aren't there that it wants but doesn't actually need.
- "helpful" automatic functionality that is near impossible to disable without obscure hacks.
- Kernel and service level hacks that make administration difficult or impossible.
- SLOW kernel with every option turned on...
- etc...
