I have just upgraded to 12.04 (I use Lubuntu) and there is something wrong with the FDTI USB driver. It looks like it is detected OK but I can’t get any incoming data.
I will keep you posted if I work out how to fix it.
Ubuntu 12.04 and FDTI USB chips.
Re: Ubuntu 12.04 and FDTI USB chips.
Fixed! :-)Spudmn wrote:I have just downgraded to 12.04 (I use Lubuntu) and there is something wrong with the FDTI USB driver.
- Spudmn
Hmmmm. Thanks Peter.
I know the hardware still works because I can get a serial stream from windows PC. My other Linux box doesn't work either and it is on 11.10.
Something weird going on here.
Compassion
What type of incoming data are you not getting? Is this with screen/minicom, or some of the other FreeEMS tools? Can you also provide the USB ID (vendor/device ID?) as well. It is in a ####:#### format, or described as such with various utilities.
- Spudmn
Nothing. I have scoped the Micro Tx and there is data there but nothing is getting through the USB Chip.What type of incoming data are you not getting?
$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 0c45:62c0 Microdia Sonix USB 2.0 Camera
Bus 002 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
$dmesg
[19005.892112] usb 2-1: new full-speed USB device number 2 using uhci_hcd
[19006.181468] usbcore: registered new interface driver usbserial
[19006.181573] USB Serial support registered for generic
[19006.181716] usbcore: registered new interface driver usbserial_generic
[19006.181728] usbserial: USB Serial Driver core
[19006.201678] USB Serial support registered for FTDI USB Serial Device
[19006.201965] ftdi_sio 2-1:1.0: FTDI USB Serial Device converter detected
[19006.202102] usb 2-1: Detected FT232RL
[19006.202112] usb 2-1: Number of endpoints 2
[19006.202120] usb 2-1: Endpoint 1 MaxPacketSize 64
[19006.202128] usb 2-1: Endpoint 2 MaxPacketSize 64
[19006.202136] usb 2-1: Setting MaxPacketSize 64
[19006.205502] usb 2-1: FTDI USB Serial Device converter now attached to ttyUSB0
[19006.205633] usbcore: registered new interface driver ftdi_sio
[19006.205649] ftdi_sio: v1.6.0:USB FTDI Serial Converters DriverI can send characters from a GTKTerm and they are appearing on the Micro's Rx. and the bit width is correct. The Rx LED is flashing when I do this. But there is never any Tx LED flashing.
The Puma USB mod shows that 2 and 9 and 3 and 11 are connected together but my board is not hooked up like this. Has anybody made this mod?
Sounds like either:
USB chip is dead
or
Link to USB chip is dead
or
Driver issue?
Though I doubt the last one.
The mod is not required, btw.
USB chip is dead
or
or
Driver issue?
- Spudmn
It most likely some sort of Linux driver issue. The hardware works fine on Windows. It only started to give me problems after I upgraded to 12.04.Fred wrote:
Driver issue?
Altium FTW!
Aaron, but you said it was not working fine on older versions of Linux too? Or did I get lost somewhere? Are you sure you don't have some insidious packages attacking the device looking for other things as I have had a few times? Preston and I had some horrible experiences with different things.
