FreeEMS-Tuner Development Diary - Don't Post!
- sry_not4sale
FreeEMS-Tuner
http://tuner.freeems.org/
"Stable" development repository
http://github.com/srynot4sale/freeems-tuner/tree/master
Live development repository
http://github.com/srynot4sale/freeems-t ... e/devtrunk
Diary:
2008-10-23
- Starting setting up the project skeleton
- Got a window rendering, including menus and status bars
- Large grid now renders, will be used for showing serial communications
- Basic interface for sending/requesting data
2008-10-24
- Read through the serial docs
Diary:
2008-10-23
2008-10-24
- sry_not4sale
Re: FreeEMS Tuner development diary
- sry_not4sale
Next task is to get it to send basic (e.g. interface/version) requests and display both the request and acknowledgment packets in the grid.
- sry_not4sale
It has python bindings and can be embedded and interacted with from what I have read/seen. Here it is running from python on my machine:
If I can't embed it into wxPython, an alternative is Matplotlib
http://www.scipy.org/Cookbook/Matplotlib/mplot3D
- sry_not4sale
Re: FreeEMS-Tuner Development Diary - Don't Post!
Well, progress has stopped as I have joined the club of broken laptops. Had the same problem with it before tho so should have it fixed pretty quick.
- sry_not4sale
2008-10-29
- Most of the FreeEMS protocol library is complete - pretty much all the code is there to send interface/firmware version requests
- The UI is now loading its layout from a customisable file (see http://www.diyefi.org/forum/viewtopic.php?f=43&t=474)
Next is to set up the serial / debugging modules - I have set up a "comms" interface that can be either for debugging, serial, or the java messaging service. Just need to fill in the logic now.
- sry_not4sale
Config and data files are now implemented.
- sry_not4sale
Logging to terminal, and file now works!!
Oh, and serial is go!
- sry_not4sale
Pluggable comms backends are implemented. Built the serial plugin including error handling, and have been testing it on a virtual serial port.
Implemented the watcher pattern for comms, which lets the gui elements monitor packets.
Built up the interface utility packet classes, have a few more bits to implement - but not far now!
Could have had a working example running, but have been thinking of the future as I go and making it extensible as possible
- sry_not4sale
Preparing the code for release after Fred tests!!!
Gui now updates showing sent packets (does not recieve packets yet)
Hardware Reset button in gui
All interface utility packets implemented!
