FreeEMS-Tuner Development Diary - Comments
Re: FreeEMS-Tuner Development Diary - Comments
Just to be clear, those two messages are in separate parts of an if/else pair... IE, they are being run on subsequent loop iterations.
Solved, logging reduced and yet another hack introduced!
We really need to figure out why we are losing bytes before and after packets.
This code works and works well it seems. I'll tidy it and push it after dinner.
fred@rwdlsd:~$ time freeemsParser binary.stream.freeems.2.stops
The length of file binary.stream.freeems.2.stops is 1560745
Attempting to parse file...
Packet number 1 ending of length 104 at char number 191 failed checksum! Received 166 Calculated 211
Packet number 2 ending of length 8 at char number 202 failed checksum! Received 166 Calculated 253
Packet number 3 ending of length 91 at char number 296 failed checksum! Received 166 Calculated 8
Packet number 4 ending of length 79 at char number 378 failed checksum! Received 166 Calculated 187
Packet number 5 ending of length 82 at char number 463 failed checksum! Received 166 Calculated 129
Packet number 6 ending of length 96 at char number 562 failed checksum! Received 166 Calculated 239
Data stream statistics :
Packets and checksums :
14844 packets were found
14838 had good checksums
6 had incorrect checksums
General issues :
13582 leading characters were dropped
1347 false starts occurred
1347 double start bytes occurred
0 stray part packets occurred
0 chars lost from false starts
Escaped byte profile :
2121 escape bytes were found
1880 escaped stop bytes were found
194 escaped start bytes were found
47 escaped escape bytes were found
0 escape pairs were mismatched
real 0m0.108s
user 0m0.084s
sys 0m0.008s
Ha! You still have issues :-)
And there is no fooling me now ;-)
Additionally, it seems to do the reception in blocks and throw a bad packet error every 10 or 20 packets it parses. I don't understand how you can get the messages like you do because the stray stops and starts can only be between real packets...
That repeated many times with varying incomplete packet and varying length/count of good packets.
Exception in thread comms.default.receive:
Traceback (most recent call last):
File "/usr/lib/python2.5/threading.py", line 486, in __bootstrap_inner
self.run()
File "/home/fred/workspaces/home/freeems-tuner/comms/protocols/IFreeEMS_Vanilla/v0_0_1/receive.py", line 71, in run
self._process()
File "/home/fred/workspaces/home/freeems-tuner/comms/protocols/IFreeEMS_Vanilla/v0_0_1/receive.py", line 104, in _process
packet = self._processBuffer()
File "/home/fred/workspaces/home/freeems-tuner/comms/protocols/IFreeEMS_Vanilla/v0_0_1/receive.py", line 186, in _processBuffer
return self._processIncomingPacket(packet)
File "/home/fred/workspaces/home/freeems-tuner/comms/protocols/IFreeEMS_Vanilla/v0_0_1/receive.py", line 232, in _processIncomingPacket
response.validate()
File "/home/fred/workspaces/home/freeems-tuner/comms/protocols/IFreeEMS_Vanilla/v0_0_1/responses.py", line 80, in validate
raise Exception, 'Packet type %s, payload length of %s does not match parsed length of %s' % (pid, self.getCalculatedPayloadLengthInt(), length)
Exception: Packet type 401, payload length of 97 does not match parsed length of 96
09:10:51 comms.default.receive ERROR processReceiveBuffer could not parse buffer. Bad/incomplete packet found in buffer before start byte 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x4A,0x03,0x3D,0x02,0xE9,0x03,0x04,0x02,0xAB,0x02,0x8F,0x02,0x05,0x03,0xCB,0x00,0xFA,0x00,0xFA,0x00,0xFC,0x00,0xF5,0x01,0x00,0x00,0xFD,0x00,0xFC,0x01,0x01,0x65,0xCC,0xCC
09:10:51 comms.default.receive ERROR processReceiveBuffer could not parse buffer. Bad/incomplete packet found in buffer before start byte 0xCC
09:10:51 comms.handleReceivedPackets DEBUG BasicDatalog packet received and processed
If I didn't know any better I'd say it was a threading issue and somehow the logs are out of order. This could also be responsible for the incomplete packets? Certainly my utility shows me no stray packets on a large run :-) :
General issues :
0 chars lost from false startsDIYEFI.org - where Open Source means Open Source, and Free means Freedom
Parse location for those with a desire to dump binary data from a terminal and parse it :
http://github.com/fredcooke/freeems-van ... msParser.c
This works well, but I may update it, so just click through from the latest commit when you want to use it.
Double post :
Retraction :
It's not that slow afterall :-)
10% python cpu usage with my xterm minimised or covered.
This is fine. It's still doing something funny with packets, but it should be fast enough, yay.
I added pysco support to it, but it didn't appear to make much difference really. 6.5% to 7.5% instead of around 10%.
Retraction :
CPU usage :
9.0 - 9.8% as is
6.5% with pysco
Is all that is required to be added to main.py for it to take effect.
I removed all pyc files each time to be certain of what i was running (probably not required).
9.0 - 9.8% as is
6.5% with pysco
import psyco
psyco.full()I removed all pyc files each time to be certain of what i was running (probably not required).
- sry_not4sale
Good news!!
I just finished logging to file too to see if it was the cause!
That's great!!
(how tf do I use/test it??)
:-p
:-p
- sry_not4sale
Make sure the following is in my_config.ini:
It writes (not appends) to data/app.log
[Logging]
to_file = True
