map repo
Re: map repo
Wouldn't we need to be able to save a map without a firmware dump or screen shot to have one of these? :-)
Re: map repo
Today's tune :
192cc/min injectors
192cc/min injectors
Re: map repo
sounds like a future feature of tunerFred wrote:Wouldn't we need to be able to save a map without a firmware dump or screen shot to have one of these?
 I'm a fan of anything but xml and somewhat human readable/editable but a step above .ini's - sometimes I like to browse a tune w/o having to use an app other than notepad
- sry_not4sale
Re: map repo
EssEss, we decided early on in the piece to use JSON as an alternative to XML for storing data. It's is a LOT nicer to read, and is also common enough for most languages to have a decent parsing library.
The tuner already uses it for some firmware version specific stuff
- sry_not4sale
Re: map repo
If we get the newlines right in the JSON map storage format, we could have a git-based map repo that can show diffs between versions of the same map
Re: map repo
Well, Rob and I went out this evening and Rob tuned the car while I drove it at break neck speeds along the freeways of Tampa, Florida. As of tonight :
Pretty awesome :-)
We got some cold start issues this morning at mid throttles until it warmed up a bit. Not unexpected with no algorithm for that... something to work on :-)
Thank you Rob! Thank you Aaron!
									- It idles better than stock.
- It has more midrange torque than stock
- It has 10mph greater top speed on the flat than stock!!
Pretty awesome :-)
Re: map repo
that is actually a really nice looking map, very smooth.
It looks a lot like other ems's i tune, manly motec.
May i ask how you are calculating the pw's
man i am not a coder, but i think i need to look at the code...
i have not been this exited since the beging of megasquirt
just to be let down by it in the end..
So far this one seems right..
i am not sure. i think part of the problem with the ms, (apart from the noise) is they have tryed to get way to fancy with everything.
i actually have the way gems works out there pw's and it s stupidly simple, and that euc is used in a lot of the world rally teams..
i have another question, when u save the table or any other settings, do you get that horrible burn stumble.
Re: map repo
Thank Rob/m2cupcar for that :-)tpsretard wrote:that is actually a really nice looking map, very smooth.
Yes, with pure physics and all parameters accounted for :-) Three phase, constants merged by hand before compile and well commented, at init time with untunable things such as cylinder volume, injector size etc, and real time with current input parameters for a final base value, then corrections are added, in this case, just a fixed 1200tick/1ms opening time guess. This may be too high and responsible for the higher than real efficiency in the top end.May i ask how you are calculating the pw's
It's well commented and viewable online, give it a whirl :-)man i am not a coder, but i think i need to look at the code...
LOL, you and me both! I'll try not to let you down!
Not just too fancy, but also just plain wrong in many ways. The are fixing stuff though, gradually, following my lead LOL.i am not sure. i think part of the problem with the ms, (apart from the noise) is they have tryed to get way to fancy with everything.
Mine isn't simple, but it is correct. It's not fancy either though, the base calcs should be exactly this, nothing more, nothing less. The corrections on the other hand, they can get fancy, and all corrections should be optional, and un-intrusive. This is the mistake ms makes, corrections you CAN'T tune out and turn off... wtf... none of that for us :-)i actually have the way gems works out there pw's and it s stupidly simple, and that euc is used in a lot of the world rally teams..
Yes, this is unavoidable and a good thing to let you know that it happened :-)i have another question, when u save the table or any other settings, do you get that horrible burn stumble.
Re: map repo
Are you sure this is true? I know you can't use a flash block being erased/programmed but there are 4 blocks in the XDP512. I don't know if you can run from one flash block while erasing/programming in another one or not and I didn't see an answer to that in my quick glance at the specs but that definitely needs investigating. And if you can then you need to use the memory such that you can take advantage of it.Fred wrote:Yes, this is unavoidable and a good thing to let you know that it happenedi have another question, when u save the table or any other settings, do you get that horrible burn stumble.
Jean
